Stupid question, smoking?
Old Apr 24, 2003 | 07:00 AM
MIKE-P-28's Avatar
Driven a turbo FB lately?
So how do you tell if its the turbo is smoking or if its the motor?
Old Apr 24, 2003 | 07:09 AM
82streetracer's Avatar
8/1 Building/Drive Ratio
Where is the smoke comming from.
The Hood? the exhaust? into the cabin?
what color smoke, what does it smell like.
Be really specific.
Old Apr 24, 2003 | 07:46 AM
S2-13BT's Avatar
Also... Does it smoke all the time? Or only after a hard run, after sitting for a few minutes etc?
Old Apr 24, 2003 | 09:22 AM
TailHappy's Avatar
Addicted to Track
Actually, I was recently wondering this too. I get the usual blue smoke through the tailpipe for several seconds when I start the car. Both the engine and the turbo are fresh, so I was curious what the culprit was...
Old Apr 24, 2003 | 02:02 PM
j9fd3s's Avatar
Community Builder
we have found that the metering oil injectors are vacuum/pressure sensitive. we had one car that smoked at idle, took the caps off the oil injectors so they see atmopheric pressure, and presto no more smoke.
mike
Old Apr 24, 2003 | 05:44 PM
setzep's Avatar
It's comming from his exhaust and he has no OMP.
Old Apr 24, 2003 | 06:36 PM
j9fd3s's Avatar
Community Builder
well silly him! turbo or engine diagnosis
1) proper way: take ic pipe off look for oil, if present could be compressor of turbo or pvc depending on pcv location. look at spark plugs, oil will leave a light brown thick residue. look at exhaust side of turbo, the turbine will also build up a light brown residue.
2) ghetto way: disconnect oil feed from turbo. plug feed line. hold compressor wheel still and start engine, look for smoke.
mike
Old Apr 24, 2003 | 07:35 PM
93redFD's Avatar
to tell if its the motor pull turbo mani from the block and rub your figures inside the motor . If you get oil on your fingures then it should be the motor burning oil( not 100% sure about this but Im pretty sure).
Also, it doesnt matter if the motor and turbos are new, I recently had a hayes motor that was burning oil after 100 miles. It all depends on who did the work.
Old Apr 24, 2003 | 07:36 PM
93redFD's Avatar
aHow much oil are you consuming??
Old Apr 25, 2003 | 08:21 AM
TailHappy's Avatar
Addicted to Track
If you're talking to me, I'm not consuming much at all. Definitely no more than the OMP should be metering. Just the nice big embarrassing puff at startup.
Old Apr 25, 2003 | 02:01 PM
MIKE-P-28's Avatar
mike
Im sorry I havent been back for a few days, thanks Setzep for answering those questions for me.
Ok it will smoke about 1 minute after starting, and continues, its greyish, foggy color, smells like gas/oil LOL The car is rich as hell.
When I remove the TB ducting theres oil in there, the spark plugs look dark in color, almost black.
I have restricted the oil supply going into the turbo to 5/64 in.
Im gonna redesign my oil drain on my turbo, I think that could be a problem, and Im curious if I added too much 2 cycle oil to it. Im gonna put some fresh unmixed gas in the tank and see if thats it...
I really beleive its the turbo, and it might be time for an upgrade, Wow I bet this turbo has 300 miles on it
Old Apr 25, 2003 | 07:59 PM
93redFD's Avatar
just pull the turbo and have it looked at buy the closest turbo tech.
Old Apr 26, 2003 | 11:40 AM
MIKE-P-28's Avatar
I would do that, the turbo is still under warranty But Id would like to see it again, the guy that did the turbo is what you would say 'busy?' maybe, anyways, I need it to race if I cant figure it out , Ill buy a new one, Id had my eye on a gt35/40 or a gt40 anyways
_Tones_
May 25, 2021 05:37 AM
13
Jan 9, 2018 11:19 AM
msilvia
15
Sep 11, 2015 12:13 PM
ZaqAtaq
Sep 5, 2015 08:57 PM
