After the storage bins, check...
Old Apr 22, 2003 | 08:38 PM
purple82's Avatar
Absolute Power is Awesome
I've seen a few Rx's that are rusting from the back side of the doors. You can see it by rolling down the window and looking at the sheet metal just inside the window opening.
Anyone else seen this?
Old Apr 22, 2003 | 10:18 PM
Suparslinc's Avatar
It's Back!
I've had the door panel off a few times, and have never noticed any rust. I do have the storage bin rust though.
Another problem area is the bottom inside of the doors. If you can find an 1st gen without any rust there you know its been fairly well kept for.
Old Apr 23, 2003 | 09:16 AM
Pele's Avatar
Right near Malloy
Far as I know, mins not rusting there... I'm gonna go this Sunday evening and check her out again... Probably put the new ignitors in and fire her up for the first time in a little over a year...
Old Apr 23, 2003 | 09:51 AM
TheAuroch's Avatar
Look inside the track of the rear hatch, check where the drain holes are, make sure their not clogged up, with leaves or dirt cause that will cause water to sit there and rust those areas out, same with the drains in the sun roof tract. I had that nice supprise in my 83"
Old Apr 23, 2003 | 10:10 AM
My SE, has the door problem.... along with the tire wells.... too bad i can't just pull off the tire wells and put new ones on *grin*.
Old Apr 23, 2003 | 11:27 AM
j9fd3s's Avatar
Community Builder
in california the only places to rust are around the drain holes for the rear hatch, and the actual sunroof panel
mike
rx7inoregon
Old School and Other Rotary
Oct 1, 2015 12:44 PM
