Question about my first RX7 - 1982
Old Aug 28, 2001 | 11:22 AM
Suparslinc's Avatar
It's Back!
Congrats. First thing you should probably do is ATF it. There is a great write-up on this procedure, which restores compression and removes engine deposits, at
http://www.mazspeed.com/faq3.htm\
as well as some other DIY projects such as tightening steering etc.
On the same site, under ultra garage and ignition questions, there is a write-up on the "poor mans MSD" that has over 100 replies and is worth checking out.
Some things to look out for; check for rust on the underside of the door panels,along the bottom. Also, in your wheelwells is a trouble spot.
all I can think of for now besides the usual stuff, feul filter (adding a second in-line filter by the carb is a good precautionary measure), air filter, change the oil every 3000 miles at most, always change the filter along with the oil, plugs, wires, dist., rotor, so on and so forth.
Old Aug 29, 2001 | 01:47 AM
DJ!
i found the best oil to use castrol gtx, do put in the second fuel filter in, with oil filter there are two you may have biggish one on there, you can buy a small verison which incresces the oil pressure a bit, and get an K&N air filter on it! Th eengine coolant i find best is to mix it 80% coolant and 20% water and the raditor hold about 4 litres ( i think top off head??). A good perforance tip is go to a auto electrican and get them to but on a electrical cooling fan. For a rebuild with a full warranty yuor look at
13b turbo from $3,800 +GST
13b standard from $3200 +GST
13b PP from $4800 + GST
13b extended port from 3400 +GST
This all aussie dollars from
Selectmaz in epping, Vic
they have a web site at www.selectmaz.com.au
they have all lot of other bits too. Their motors are good i brought one from them it run great.
Old Aug 29, 2001 | 01:56 PM
Turbo FB.'s Avatar
I think DJ ment 80% water 20% coolant, Water has much better cooling properties than coolant.
Old Sep 6, 2001 | 09:16 AM
jeremyriv's Avatar
Better idea!
How about this guys: Get a winter beater! This is what I did up here in Maine, USA.
Mine is a 1983 GSL no rust and going strong with only 65,000!
MY BABY..... *drool*
Th0m4s
Feb 26, 2019 02:04 AM
smikels
Rtek Forum
May 12, 2016 12:34 AM
OrangeMax
Aug 22, 2015 12:05 PM
WLD.RX7
Aug 16, 2015 09:43 AM
Professorpeanutrx7
Aug 15, 2015 01:38 PM
