FD Front and Rear Rotor housing different?
Old Apr 21, 2003 | 04:59 PM
toddp31's Avatar
Here is the situation: I picked up a FD block from a local shop that they no longer wanted. I am going to pull it apart and check all the clearences, then overhaul it. I noticed that the front rotor housing has the R stamped on the top. Does it really matter what order they go in? The only difference I can see is the Knock sensor should go in the front rotor housings. Would there be a problem if you just had the rotor housings swapped? I am just curious and it makes me question the quality of this shops work. Thanks
Old Apr 21, 2003 | 06:04 PM
j9fd3s's Avatar
Community Builder
they are different. the air injection passages are mirror imaged, so thats the difference
mike
Old Apr 21, 2003 | 06:20 PM
toddp31's Avatar
Mirror imaged? Can you explain a little more, you lost me.
cdn
14
Sep 10, 2015 06:23 AM
Brice_Brice
Aug 18, 2015 10:42 AM
cdn
2nd Generation Non-Technical and pictures
Aug 11, 2015 08:59 PM
