All you Single Turbo guys/girls!!!!
Old Apr 20, 2003 | 04:21 PM
MARKMEMCAJ's Avatar
Noob!
Hey everyone, i was wondering what all of your opinions are on the Single turbo conversion. Some of u have it and some dont, just post your reasons for doing it and if u regret it or love it to death!!! Thanks
Old Apr 20, 2003 | 05:03 PM
bigmack000's Avatar
Rotor DEMON !
i am doin my convertions for more power and not as much crap to worry about with stock twins. i dont think i will regret it at all when i am done mine. you can see the size in my sig the turbo i am putting on by one of the stockers.
joel
Old Apr 20, 2003 | 05:15 PM
Dougie_fresh_007's Avatar
PROS
no, or almost no vaccum soliniods
usually more power... unless u get a smaller turbo
less heat
cleaner engine bay
less clutter... less stuff
CONS
slower spool...
umm thatz all i can think of....
id go for it... jus because... u have soo much more potential..
Old Apr 21, 2003 | 06:11 PM
apexkw's Avatar
in slow, out fast!
pro its cool as hell if you got a single. because its so much simpler. dont have to worry about a funky power band kicking in on a turn and sending you out of control. and like dougie said...on my setup i dont have a rats nest AT ALL. thats reason enough for most people to want to go single. as far as lag is concerned my apexi turbo comes on full boost by 3000rpms. i think the only real con is that it cost $$$$ to be single. and lots of it. i did all the work myself with the help of a couple of good friends and it still cost me at least $8000 and i am still dont have everything i need yet.
Old Apr 21, 2003 | 10:28 PM
mark57's Avatar
Temple of Cornd0g
Single or parallel turbo is the way to go. YOu won't regret it......just don't get too be a turbo and street port the motor to reduce lag to near zero.
Old Apr 24, 2003 | 05:34 AM
insomniac's Avatar
I went single because of my boost problems with the twins.
Knock on wood, haven't had any boost problem with my single yet.
Old Apr 24, 2003 | 01:11 PM
IRPerformance's Avatar
Sponsor
Aside from what has been already mentioned, makes the car MUCH easier to work on becuase of more room in the engine bay. I've never had good experiences with stock rebuilt turbos. A new properly sized single is the way to go.
Old Apr 25, 2003 | 03:03 AM
OzFeTt's Avatar
and don't forget it makes the car a HELL of a lot faster
you gotta love that single-turbo 5000rpm boot up the **** :P
Old Apr 25, 2003 | 04:22 PM
MARKMEMCAJ's Avatar
Noob!
thanks fellas, anymore opinions?
Old Apr 25, 2003 | 04:29 PM
AJatx's Avatar
Lag is a questionable CON for single turbo.
It really depends on your choice of turbo and homework for it.
My GT35/40 can hit 15psi around 3krpm.
PROS:
-Easier access to other components in engine bay
-Cooler compressor charge at lower boost levels; yet flowing more than stock turbos at the same boost level.
-Above will also have less stress on your turbo.
-Reduces the complexity of sequential twins.
-All the things you learn by going through the experience.
CONS:
-Takes some time to tune
-Requires $ and understanding
J
Old Apr 28, 2003 | 11:02 PM
Northwest FD3S's Avatar
Rich Hoe
When converting to a single, do you need to have the engine pulled and rebuilt & dowelled? Or can you put a single turbo on and just upgrade the fuel and ecu.
Old Apr 29, 2003 | 09:06 AM
apexkw's Avatar
in slow, out fast!
you dont need to get the engine pulled and dowled unlesss you are making some massive hp numbers. just dont skimp on the fuel stuff.
Old Apr 29, 2003 | 10:14 PM
Rich Hoe
Fuel
I have the trickest fuel setup. I will post pics soon, took me more than 4 days and about $1,000 just on lines connectors & regulator.
Old Apr 29, 2003 | 10:35 PM
loll u said trickest
Jan 11, 2016 04:08 PM
Aug 21, 2015 08:35 PM
