Power FC Removed OMP and now car runs like butt.
Old Apr 19, 2003 | 04:50 PM
Resource's Avatar
I've been doing some searching and it says this will cause the ECU to go into to limp mode. Is this true? How can I fix this besided putting the OMP back on?
I have the Power FC.
Thanks!
Old Apr 20, 2003 | 06:47 PM
Ranzo's Avatar
Wire resistors in there to simulate the load of the OMP so that the computer thinks there is one on there.
Old Apr 21, 2003 | 05:45 AM
twokrx7's Avatar
Need more sleep
Assuming you replaced the oil injectors with solid plugs and the ECU is running in limp mode (not sure if this is part of the PFC programming) ... you can plug in the OMP and leave it underhood, just tuck it, wire it, or tie wrap it someplace safe.
Old Apr 21, 2003 | 12:03 PM
Resource's Avatar
Does the power fc have a limp mode?
I already cut the wires going to the OMP.
Old Apr 21, 2003 | 01:32 PM
SPOautos's Avatar
Hey, where did my $$$ go?
I posted on your thread in the 3rd gen section but maybe you havent seen it so I'll post here.
I'm not running the omp, I just cut it out from the harness and blocked off the omp on the front cover. I also screwed in a bolt on top of the engine where the oil injectors are.
I cant imagine what the problem would be unless you didnt use a bolt in the oil injector hole.
STEPHEN
Microtech
Aug 23, 2015 11:04 AM
rx7brandon
Aug 16, 2015 10:55 AM
KAL797
Test Area 51
Aug 11, 2015 03:47 PM
