My boost control setup - perfect 10-8-10 pattern
Old Apr 19, 2003 | 04:04 PM
damian's Avatar
DDH Motorsports
Top Answer: 1
Ok, as many of you already know I have tried many boost control setups with no success in eliminating spikes or keeping boost at stock levels. Finaly I did a setup that gave me NO spike on primary or transition and held boost wherever I wanted. I am sure some one has already done this setup but many have asked me for detaisl so here we go.....
First, some background and theory based on what I learned from the gurus. I tried changing pills (like 40 combinations), no sucesss....I tried bleeder valves where the pills were, no success...I tried bleeder valves without the ecu, even a 3/8 valve could not bleed enough, no success.
The reason many of these setups fail to control spike (and/or maintain boost level control) is because most of these setups restrict what the actual controler (solenoids in the stock system) sees for pressure.....this restriction REDUCES the controlers reaction time, thus creating spikes. What you want is the controller to see all the pressure (ie no pill or restrictor bleeder valve) so that it can have the fastest reaction ability. However, the stock solenoids/ecu is pre-mapped, so you can never give it the full pressure signal to maintain stock boost. Really what you want is a controller (or solenoid) that can handle the full pressure signal and be adjustable in order to tweak boost settings. Also, you want to minimize the amount of hose in the loop between the pressure source, controler, and actuator... this can also help response time (spiking).
With that said, I decided to use ball/spring valves for both my wastegate and pre-control valves because they can take the full pressure signal and you can adjust the 'breaking point' of the valve.
Here is an image of my setup with comments below:
Some notes:
I know you can get homedepot style ball/spring controllers for cheap, but I wanted these controllers for the professional look and design...so keep the 'why did you buy those ...blah blah.' comments to yourself.
If you decide to get these controllers BE SURE to get the RX version with the lighter spring. Even at a very low setting I am at 10 lbs, with the harder spring I don't know if you can get it at 10 with its lowest setting.
If you set it up like I did then you want to start both controllers totally 'open', meaning the ball/spring combo in the valve are just barely held together. I got the valves to this point by opening them until I could hear the ball/spring 'jiggle' when I shooke it, then closed the valve a bit, then shook it, then closed a bit, then shook it, just a bit by bit until I no longer herd the 'jiggle ' of the ball/spring. This allows the actuator to see a lot of pressure and will keep boost low to start. I did this for both the wg and pre-control.
The interesting thing was that on my first runs I was already close to a perfect pattern, I was gettin a 9-7-8 with ZERO spiking on primary or transition. I set the wastegate first so that post transition boost went up to 9ish, then adjusted the pre-control to get my primary to 10ish, then the wastegate again to get post transition boost to 10ish. I have a really nice 10-8-10 with no spikes, and its really more like 10-9-10 becasue the transition has become very quick.
Keep in mind I need to keep 10lbs boost level because I still have a stock ecu, but the following flow mods: intake, downpipe, and catback. So as you can see with 3 flow mods the stock system (with pills or valves or whatever) could not manage the spikes/boost../..but this style of setup can handle it just very well and I have plenty of adjustment room when I get an intercooler and PFC in, then it will be easy to adjust it to 12-10-12 pattern.
Also, you can use bleeder valves where I use ball/spring, but you may not get the same boost responce and be sure they can flow enough or you will not be able to keep your boost down!!
This is where I got my valves
http://www.boostcontroller.com
anyway, comments, feedback, are welcome....I really am interested if anyone has comments on the oil-injector plumbing deal.
Old Apr 19, 2003 | 04:20 PM
damian's Avatar
DDH Motorsports
Top Answer: 1
Here are some helpful links if you want to make ur own valves:
http://www.gusmahon.org/html/boostcontrol.htm
http://www.xmission.com/~dempsey/perform/grainger.htm
by the way, I am going to try to post a vid of my pattern in a few different gears.
Old Apr 19, 2003 | 04:24 PM
rynberg's Avatar
Excellent post and write-up Damian. You are really contributing to the forum!
Old Apr 19, 2003 | 04:33 PM
damian's Avatar
DDH Motorsports
Top Answer: 1
thanks rynberg :-)
Old Apr 19, 2003 | 04:46 PM
psi4psi's Avatar
just curious what your pattern was before u got the valves and where did you get that hose for the BOV and CRV?
Old Apr 19, 2003 | 06:31 PM
damian's Avatar
DDH Motorsports
Top Answer: 1
I got that clear hose (with white thread criss-cross pattern) from homedepot, it is only temporary until my yellow silicone comes, but it does look kinda cool :-)
my boost pattern was all over the place depending on what setup i was trying, when i tried the stock setup with the different pills, I could not adjust take out the transition spike without overboosting on the primary,
some tests gave me huge spikes to 13-14 psi on the primary (luckily I got off teh gas before fuel cut) and when i would change the pill to drop the primary to 10ish, I would get a huge spike on the tranistion (13-14 psi), so either way I was screwed with that setup....
using bleeder valves instead of pills did not help.
Old Apr 19, 2003 | 07:32 PM
FDjunkie's Avatar
Excellent write up and congratulation on getting control of your boost! Did you consider at using the Dawes Device for its quick response?
Old Apr 19, 2003 | 07:43 PM
damian's Avatar
DDH Motorsports
Top Answer: 1
thanks fdjunkie, yes i did use a daws device a few setups ago, but it is a pain in the butt to adjust between runs, the valves I have now work the exact same way internaly as the daws device (ball/spring) but they have a nicer 'case' and a **** for easy adjustablility.
its kinda funny, now I have a small box of parts from all my setup attempts, a daws device, 2 1/4 bleeder valves, and 2 3/8 bleeder valves.... heheheh
Old Apr 19, 2003 | 07:45 PM
xstacy7's Avatar
I love when things work
Damian, I love your write-ups. You are the perfect owner for a 7
Old Apr 19, 2003 | 07:52 PM
damian's Avatar
DDH Motorsports
Top Answer: 1
heheh, thanks xstacy7 :-)
I dunno know about a 'perfect' owner...but darn close
(I get a lot of help from the other peeps on this forum and other local 7 owners, they deserve much of the credit)
Old Apr 19, 2003 | 10:04 PM
RonKMiller's Avatar
Blow up or win
You'll never guess what I have sitting in a box in my garage right now! The only difference is mine is going inside the cockpit with the vernier cables they provide.
You just saved me a lot of time and messing around. Thanks.
Ceramic ***** rule. (so do brass ones, )
EXCELLENT write up. I never thought about getting a red one and a black one.
Great to see some creative lateral thinking just when EVERYONE thought the book had been written on boost control.
Old Apr 19, 2003 | 10:37 PM
duboisr's Avatar
That is the hallman (red ) control Garfinkle has for the non seq BNR stage 3s. .Will that set up on the wastgate only work better than putting the valve in the pressure line from the uim, and blocking the second nipple . He has not installed any thing yet as he and his son are making an alum pully set .
Old Apr 19, 2003 | 10:38 PM
bureau_c's Avatar
Great write-up Damian...this is addressing exactly the thing I need to work on right now. It seems odd that with the lighter weight ball and spring, and bypassing ECU control, that your lowest setting isn't closer to wastegate spring pressure, i.e. 7lbs or so.
As for Ron's plans to run the remote cables...are you going to do that with both of them? How much of a twist of the **** does it take to go from say 10 lbs to 12 lbs? There's no way really to have an easily felt detent or something to change between two set points, plus if you have to tweak two ***** to get it right...I guess I don't see a big advantage for our cars to the cockpit control, other than that it will make initial setting a bit easier.
jds
Old Apr 19, 2003 | 10:48 PM
damian's Avatar
DDH Motorsports
Top Answer: 1
Originally posted by duboisr
...Will that set up on the wastgate only work better than putting the valve in the pressure line from the uim, and blocking the second nipple ...
well, I would think my setup will give better response on the actuator because it is routed right from the closest pressure source (primary turbine outlet) instead of getting pressure from all the way through the intercoller and tubing when you connect it to the ium. But I don't know if the difference is enough to notice, I'm just speculating based on the physics of it.
...and , not capping the actuator allows the vented pressure go back into the plumming that the oil injectors see, but i dunno much on that subject.
Old Apr 19, 2003 | 10:49 PM
bureau_c's Avatar
Someone who was selling ball-and-spring controllers told me to just use a T so both actuators see the same pressure and you can use just the one controller. Do you see any downside to that? Obviously, you couldn't adjust the two separately, but I'm wondering how necessary that capability is? When people install an electronic boost controller on the sequential system they don't buy two.
Also...yeah, I'm full of questions...I'm trying to think what the downside is of not retaining the ECU control. Surely there must be something, but I can't think of it, especially in light of your results.
jds
Old Apr 19, 2003 | 10:58 PM
damian's Avatar
DDH Motorsports
Top Answer: 1
thanks bureau_c
well, I did turn it enough to get the spring/ball not to jiggle freely, so that must have been enough to create a few pounds of added boost.... not to mention that the restiction of the internals of the valve may also add to the equasion, in other words, if you removed the ball/spring and had just an open valve, it may add a pund or two due to its inner diameter ristriction
I may, i was going to buy the remote kits at the start, but decided to test teh valves first to see if I liked them, the funny thing is that it would be 'nice' or 'cool' to have then on the inside, but its hard to find a reason 'why', I mean, its not like I'm changing the boost once I set it....but, I originaly did have a plan to route the two control ***** into the inside of the glovebox, so when you opend the glovebox the two ***** would be agaisnt the back wall of the box....that would be sweet, but again, why when I never plan on changing them often.
hehe, well, I never got to 12lbs because I did't want to (stock ecu)...but I would say it was about 1/2 on the wastegate for a full pund of boost...so with the light spring/ceramic ball you really do have very nice resolution of control on the boost
I agree, I really like the hallman controllers, but my one complaint would be that there is no markings, ie a bezel on teh controller body with lines and a arrow mark on the **** so that you could 'mark' where your good boost setting is.
Old Apr 19, 2003 | 11:02 PM
JONSKI's Avatar
5yr member, joined 2001
Old Apr 19, 2003 | 11:04 PM
damian's Avatar
DDH Motorsports
Top Answer: 1
absolutly necessary !! the controllers will not be set the same...you need to be able to adjust them differently or you will not be able to modify the primary spike (or transition spike) seperatly from post transition boost level.
that is becasue it is assumed that the transition is fine and you just need to control post transition boost....many people with electronic controlers still change the pre-control pill to help control primary boost or the transition spike
well, I'm sure I havent though of everything, but one downside is that if you cap stuff off, then you might mess up the pressure/vaccumm signal that the oil injectors see since they are sharing the same plumming as the wg/pc control solenoids/actuators....but I kept that loop in tact with my setup....however I dunno if there still might be a hiddin issue there.
damian's Avatar
DDH Motorsports
Top Answer: 1
Originally posted by JONSKI
heheheh, thanks JONSKI
Old Apr 19, 2003 | 11:06 PM
damian's Avatar
DDH Motorsports
Top Answer: 1
Originally posted by RonKMiller
...Great to see some creative lateral thinking just when EVERYONE thought the book had been written on boost control.
thanks ron,
I am really tempted to do the remote setup with the ***** in teh glove box, but its so hard to justify when i never am gonna change the setting....but 'cool factor' my be enough lol
Old Apr 19, 2003 | 11:19 PM
bureau_c's Avatar
Given that my transition spike is really what I'm most worried about...I guess I'll get two!
It sounds like, even if you went with an electronic controller, it would be to your advantage to retain the Hallman instead of a precontrol pill in order to benefit from the quick spool-up there as well.
I'm definitely going to do this. Now I just have to decide if the drool factor of the Hallman's are worth the added expense compared with the $12 Ebay version, which really should be the same in terms of performance I guess. Well...maybe not, since you went with the ceramic ball and lighter spring. Anyone know if any of the cheaper ones (not necessarily $12!) use the lightweight components? What the hell...its either the Blitz SBC-iD or totally ghetto. There is no in-between!
jds
Old Apr 19, 2003 | 11:25 PM
duboisr's Avatar
The oil vacuum line is from the air intake elbow , Gar has remade that line . His actuator has a stronger spring in it . He has not installed the controler yet so I will show him your idea . Thank you for the reply and good work . good skill...
Old Apr 20, 2003 | 12:37 AM
damian's Avatar
DDH Motorsports
Top Answer: 1
ahh yes duboisr, if he made the oil vac line then he is ok there, let me know what he thinks after you show him my setup...
Old Apr 20, 2003 | 02:28 AM
duboisr's Avatar
Will do
Old Apr 20, 2003 | 10:20 AM
apneablue's Avatar
This calls for a party! Damian, you da man!
Edit: You know, this seemed all too good until I saw the price of those valvas...I think I will hold out and get an electronic boost controler...This is damn good write up though!
