Block off plate?
Old Apr 18, 2003 | 08:51 AM
Rex79's Avatar
Block off plate?
I ordered a Full RB Exhaust system yesterday(1000$ CDN, ouch!) and I was wondering if it came with the block off plate? I don't feel like emailing RB because it would take a while to get an answer.
While I'm at it, I read the post on pros/cons of removing the air pump.. somebody says that if you remove it you can get high at lights... why would that happen? I mean your cat is removed so the air pump is just pushing air for nothing right?
The reason I bought that system is that I think I had a hole in muffler(because of the damn backfires) and I think that my thermal reactor wasn't working anymore...
Might as well grab an extra 22HP
I hope that with the new system my backfires will disappear... or else I guess I'll want to mess around with the timing, the a/f ratio and everything... I'm positive that I'm running too rich at high RPM(I only get my backfires when I shift at 5500RPM++).
I think I'm gonna buy a A/F Ratio Guage soon..
Old Apr 18, 2003 | 10:34 AM
Rex79's Avatar
ttt
Old Apr 18, 2003 | 10:47 AM
slag's Avatar
22 hp?
I have read its more like 6-10 hp max, but thats just some posts I have read.
Old Apr 18, 2003 | 10:50 AM
jayroc's Avatar
Did you swap out your points ignition? If not I think you'll be a bit disappointed in your new exhaust...
Old Apr 18, 2003 | 10:55 AM
jayroc's Avatar
I don't think the RB exhaust comes with a block off plate, but they're only like 6 dollars.
Are o2 housings built into RB headers for a 12a? I'm not sure...
I'd go ahead and remove the air pump. I haven't had any trouble the times I've done it.
Old Apr 18, 2003 | 11:05 AM
Metallic_rock's Avatar
Ride 'n Style
Ok, I've done this... remove the air pump - gain hp just from removing it!
Order the block off plates from Mazdatrix. (you'll get them probably before you get your stuff from racing beat)
I'm not positive on the 79 setup, but if you have the tube coming up from the cat to the intake, plug it on the exhaust before you install the new exhaust system, and take that little pipe off the car. Make sure you get that block off plate too. (for where the pipe goes into the intake)
if you're doing all this crap, you might as well do a rats nest removal as well. (you're not going to pass smog, anyway) check www.mazspeed.com there is a tutorial under the facts section.
Old Apr 18, 2003 | 11:40 AM
Wankelguy's Avatar
My FSP Fiesta eats Jettas
The Racing Bleat headers usually come with the ACV block-off plate. You will need to get a block-off plate for the heat exchanger flange, though. There are no cats on thermal reactor equipped cars ('79-'80). Once you install the header, the ACV gets tossed, as well as the heat exchanger (if you got the whole system, including presilencer). The air pump can go, too, obviously. The air pump should never be removed while catalytic converters or a thermal reactor is present, though. It provides cooling air to keep these components from overheating. 22 hp seems a little too optimistic to me, I'd expect more like 10-15 hp gain, realistically. And yes, you should install an '81 or newer electronic distributor to get rid of the breaker points setup.
Old Apr 18, 2003 | 11:58 AM
MosesX605's Avatar
My wife bought me 2 RX-7s
Racing Beat quotes a power increase of 20% over stock, so 22hp is right on the money.
Old Apr 18, 2003 | 01:16 PM
Wankelguy's Avatar
From my 1985 Racing Beat catalog:
"When installing headers on a rotary for street use, there are two general approaches; short primaries and long primaries. If the two primary pipes are brought together early in the exhaust system, the noise will only be moderately louder than stock, and the power increase will be about 7 percent over stock at 7000 rpm. Conversely, if the two pipes are not collected until just before the muffler, there will be a distinctly "metallic" character to the exhaust, noise will increase, and the power increase will be the same or slightly higher. All of the above applies to non-ported engines".
Old Apr 18, 2003 | 01:21 PM
Narcisse91's Avatar
From their website, which is probably more recent than '85:
"These exhaust systems offer excellent horsepower gains when you require a muffled exhaust system for your stock-ported engine. The actual horsepower increase depends on which year/model stock RX-7 exhaust system you are comparing to, but a 22% increase at 7000 rpm is typical. Thanks to the combined efforts of the Power-Pulse Presilencer and the Power Pulse Main muffler, the exhaust noise is only slightly higher than stock, with a very low, pleasant character."
Old Apr 18, 2003 | 01:50 PM
Wankelguy's Avatar
Well, well, it seems that Racing Bleat has changed their tune over the years, doesn't it? I wonder what has changed? The cars are the same, the products are the same, hmmm this is a mystery indeed...
Old Apr 18, 2003 | 06:47 PM
MIKE-P-28's Avatar
Driven a turbo FB lately?
I think it comes with the 2, but why pat $6 for something you can make in about 10 minutes?
Old Apr 18, 2003 | 08:20 PM
Rex79's Avatar
I don't weld so good..:p
Old Apr 18, 2003 | 08:37 PM
MIKE-P-28's Avatar
Weld? Weld what?
You were talking about block off plates, thats cutting and drilling some Aluminum plate?
Old Apr 18, 2003 | 08:38 PM
Rx7carl's Avatar
Airflow is my life
Weld? You dont need to weld. Just use the gaskets as templates and cut some sheetmetal to make your own plates.
Old Apr 18, 2003 | 09:36 PM
brianmcd's Avatar
I just ordered my exhaust tonight. i'm gonna remove the air pump. Is there anything that needs to be plugged when you remove it, besides the block off plate, or can i just undo everything, pull it out, put on BOP, and be done? And yeah, I think 22% is what you get for the whole system. That 7% seemed like it was just the headers, maybe?
~brian
Old Apr 19, 2003 | 12:07 AM
Matty's first 1st Gen's Avatar
Boosted 7
how thick should the aluminium be, i have some but its very thin, a bit thinker than thick ducting?
Old Apr 19, 2003 | 12:58 AM
FB II's Avatar
well, my car is putting down 110rwhp, about 130 fwhp and all i have done is the racing beat header and custom 2.25 piping. so it's gotta be something around the 22% range. ATLEAST.
Old Apr 19, 2003 | 09:38 AM
MIKE-P-28's Avatar
The stuff I have is 3 / 16 thick, so almost a 1/4 inch
Old Apr 19, 2003 | 02:49 PM
Rx7carl's Avatar
Airflow is my life
Nah I did it with thin alum too. As long as its not like tinfoil LOL you should be fine, just use some kind of gasket sealer with the thinner stuff so you dont have a vacuum leak. The steel RB plate is like 3/16" plate steel, wayyyyyyyyyyyyyyyyyy too much overkill to block a silly little port. It weighs like 2 lbs
Old Apr 19, 2003 | 05:36 PM
vipernicus42's Avatar
Rotoholic Moderookie
Yeah, but it's amazing how much the price can rise.... 6$ US.. jeez that sounds so damn cheap..
plus convert to canadian.. plus shipping and customs.. that one damn 6$ plate ended up being 23$ out of my Visa! DAMN!
Old Apr 19, 2003 | 05:37 PM
Aico's Avatar
That's just a header and not an entire exhaust system
Old Apr 19, 2003 | 09:28 PM
MIKE-P-28's Avatar
I tried it with some thin sheet metal, works really good LOL NOT. It leaked like hell and didnt hold up worth a crap.
Old Apr 21, 2003 | 12:59 PM
Critoris's Avatar
Okay, the RB setup DOES come with blockoff plates but doesn't come with an O2 bung. I had them weld one onto my Streetport header for $20 (right at the collector and the sensor ends up mid-stream). I grabbed an O2 sensor off a junked Hyundai, screwed it in, and it's pimpin the A/F Meter now where the clock used to live. I went to Mazdatrix and they did the O2 bung.
