Heres some nice carbon fiber hood scoops and items...
Old Apr 18, 2003 | 07:50 AM
SoRRoW's Avatar
MY NEW NAME IS ROTARY 7S
I like the bigger hood scoop,
But I want air forced to the carb,will this vent catch it ..and if it was reversed it will pull air from the engine bay right?
http://www.carbontrix.com
Old Apr 18, 2003 | 07:54 AM
Im soryy, but that just looks bad. And I can only imagine what it would look like on a 1st gen. Now another thing with scoops on a 7, is that there aerodynamics are sop precise. Just that can screw itr up, becase either way the scoop is facing, you will be pushing more air out that pulling in.
Oh yeah, and I hope they dont drive that Eclipse on the road. Looks kinda lame!
Old Apr 18, 2003 | 08:05 AM
SoRRoW's Avatar
If you turn the hood scoop around it dont look much diffrent then a TII hood
I dont know what you have in mind..I rather use this to bring air into my carb ..then to run some dryer hose to plastic pvp piping thinking its a cold air intake
Old Apr 18, 2003 | 08:16 AM
gamble302's Avatar
roadkill hats rock
if it doesnt hotlink
i was thinkin of using an old wrx vent and puttin that over the turbo for venting, when i go turbo that is
Old Apr 18, 2003 | 12:15 PM
SoRRoW's Avatar
What year is that from ..
I want one off of a early 80s 300zTurbo..
But im looking around,,I got a guy who wants to trade stuff for my clutch...and he was gonna get me a hood scoop.Im tired of waiting and holding ****.
Old Apr 18, 2003 | 12:38 PM
All im saying is, that putting a hood scoop on a 7. You will be pushing out more air than you will be pulling in, and screw up the aerodynamics!
Old Apr 18, 2003 | 12:50 PM
81Rex6port13b's Avatar
I Push My Car Real Fast!
when i was carbed i was going to put an oval filter on my carb and cut a whole in the hood to make it stick out.
so about 1-2" of the filter would stick out from under the hood. in my opinoin it would look cool and let the carb breath easy.
Old Apr 18, 2003 | 01:13 PM
AdrenalifeRX7's Avatar
Are you gonna shift?!
Here's my hood vent right over the turbo. I just wish everything was made out of CF.
Old Apr 18, 2003 | 01:17 PM
SoRRoW's Avatar
Is that a fiberglassed hood or just an insert?
Old Apr 18, 2003 | 01:23 PM
MarkPerez's Avatar
Tennis, anyone
Yuk,, ! so, what you want is ... a vent, or a scoope ?
not many scoopes look good on the 1st gens. For a
scoope on the hood to function right there is more to fab. such as, the air box that is air tight when the hood
is closed. A ram air type deal on the 1st gens takes
alot of engineering to turn out right. In my case, on my
silver hood i installed a NACA duct right over the air cleaner and drilled holes in the top of the stock air box.
that wasn't the best idea. I got another hood (black)
and left it alone, on the snorkel of the stock air cleaner
i installed some IC piping and fabed. a small inlet 'scoope' at the end. that is screwed right behind
the passanger side headlight lid, then i vented the light
lid. My engine pulls air only from the outside of the engine bay. call it, cold air, fresh air, call it late for dinner,
but it works real good, and looks ok too.
Old Apr 18, 2003 | 01:34 PM
Manntis's Avatar
add to cart
No such animal. In 1985, Nissan released a 300ZX, but there was never a 300Z in the early 80's or any other time.
Old Apr 18, 2003 | 01:44 PM
It's just a cut sheetmetal insert.
Old Apr 18, 2003 | 02:01 PM
SoRRoW's Avatar
300 zx TURBO before the body change in 89 (?) to the last gen..
Old Apr 18, 2003 | 02:40 PM
MarkPerez's Avatar
Tennis, anyone
Are you meaning the early scoope that sits on top of the hood. or the other NACA/vent that is flush on the hood. I have 3 of the NACA/vents from Z cars. there pretty big ,,in size though. and bolt on.
Old Apr 18, 2003 | 04:45 PM
SoRRoW's Avatar
the ones that sat on the left side on top..ill see if i can find a pic
Snoopy FD
Dec 8, 2015 01:45 PM
matty
Interior / Exterior / Audio
Sep 29, 2015 12:27 PM
