What is the main purpose of the Tar?
Old Apr 17, 2003 | 09:14 AM
SoRRoW's Avatar
MY NEW NAME IS ROTARY 7S
It it to block heat or reduce body rattles?
I took the heat shield off a long time ago when I got my exhast done..Im gonan take out this tar...and put in black carpet.I got a feeeling its gonsn be hot as hell in there..
Old Apr 17, 2003 | 09:28 AM
RacerX7fb's Avatar
paradox
Its mainly an insulation for road noise reduction.
Old Apr 17, 2003 | 09:48 AM
Maguire's Avatar
Born 2 Brap
I think it reduces vibration of the body so it makes less noise. Kinda like putting Duct tape on a drum head. I doubt it insulates much from heat, but i suppose it could some.
Old Apr 17, 2003 | 10:09 AM
Pele's Avatar
Right near Malloy
If it got all that hot, it'd goo up and soakthrough the carpet... I don't think it's for much heat insulation at all... I think the heat shield is for that, and even then, if the car's moving, it shouldn't matter as the air flow should remove most of the heat. Most of the heat leaves the exhaust out the tailpipe anyhow.
Old Apr 17, 2003 | 12:12 PM
O 16581 72452 5's Avatar
The infamous number guy!
It's an insulator for road noise, you're going to feel like you're driving in a tin can when you take it out.
Old Apr 17, 2003 | 12:13 PM
jeremy's Avatar
male stripper
bawahahaha, great analogy. what they said, mainly sound insulation.
Old Apr 17, 2003 | 12:23 PM
Narcisse91's Avatar
Damn, I replied to this but the post isn't showing up.
You're talking about the undercoating on the bottom of the car? Like everyone said, it will deaden sound, but it does a LOT for rustproofing as well. If that was bare steel, in some parts of the country the car would barely last through a single winter.
Old Apr 17, 2003 | 12:44 PM
SoRRoW's Avatar
Not the undercarrige coating ..its under the carpet...
Im not to concerned about sound,I doubt I will,be able to hear **** over my exhast..
Old Apr 17, 2003 | 01:06 PM
82transam's Avatar
Never Follow
**** under the carpet is for noise too.
Old Apr 17, 2003 | 01:44 PM
Maguire's Avatar
Born 2 Brap
hehe, thanks. i used to have a home recording studio. made some bank off it too..
Old Apr 17, 2003 | 02:46 PM
Cody's Avatar
SKELETOR!
The rubbery tar under the carpet is definately for road noise insulation. Without it, your car would SOUND like the inside of a drum.
If I didn't still have my sound tar, I would need to wear earplugs (almost already have to) with my open manifold exhaust that exits right under passenger floor.
The tar BELOW the car, if you have some, is weather related. If its solid, you should be ok.....but if it's all cracked up, and missing some pieces, and you want your car for longer than another year....you might want to rip it off, and have it prepared and redone. Otherwise, its just a nice place for the water and salt to collect and eat your floor out.
Turblown
Vendor Classifieds
Oct 17, 2020 03:25 PM
dona1326cosprings7
Oct 29, 2015 06:47 AM
FC3S Timmy
16
Oct 3, 2015 01:08 AM
