leaking oil...
Old Apr 16, 2003 | 08:02 PM
racerfoo's Avatar
Exclamation leaking oil...
well, i dont really know what happened. i went to take my car for a drive, and about 1/4 mile down the road my oil light pops on. wierd...the unit never really seemed to work right, but i figured i better not risk it. so i turn back and come home, with the gauge sitting on 0 and bouncing up about 1/4 of an inch the whole way home. i get it into the garage, and check my oil....none on the stick, so i fill it up and the car smells like oil big time. i look under it, and it looks like from my oil cooler back on the driver side is covered in oil. should i be worried about anything? or as long as i find and fix the leak and fill it with oil it will be alright? my temps seemed to be fine, the fans never came on (untill i tuned them on manually).
Old Apr 16, 2003 | 08:57 PM
Mr rx-7 tt's Avatar
rotary sensei
Re: leaking oil...
Don't EVER use any fixit in a bottle. Have it towed to a shop, don't even start it, or you will end up buying a motor @ 5000.00.
Old Apr 16, 2003 | 09:04 PM
racerfoo's Avatar
not a leak in the block, i mean a popped off line or something from my oil cooler...thats what it seems to be.
Old Apr 16, 2003 | 09:07 PM
Mr rx-7 tt's Avatar
rotary sensei
Then find the leak and repair it or have it towed somewhere to someone who can find it and fix it. If you run the car without oil due to a leak the engine will be ruined.
Old Apr 16, 2003 | 09:24 PM
racerfoo's Avatar
can there still be oil if the stick is dry? cause i was getting slight oil readings on the gauge...but the stick had none on it.
Old Apr 16, 2003 | 09:26 PM
johnchabin's Avatar
fixit in a bottle? I missed something...
Old Apr 16, 2003 | 09:37 PM
racerfoo's Avatar
me too....but whatever that stuff is...i'll take a few gallons for all the problems i have with this car haha
Old Apr 16, 2003 | 09:57 PM
Mr rx-7 tt's Avatar
rotary sensei
No oil on the stick means not enough to run the motor...
fixit in a bottle= bars leak fix etc. Not good.
Old Apr 17, 2003 | 02:02 AM
poss's Avatar
Slower Traffic Keep Right
except he's talking about oil, not coolant
find the leak, fix it right, and be on your way.
Old Apr 17, 2003 | 07:20 AM
johnchabin's Avatar
How much oil did you have to add to get it back to normal?
Oh, and the reason I was questioning 'fixit in a bottle' is that this was never mentioned in his original post... I'm not sure where this came from.
ls1swap
Jun 3, 2024 03:25 PM
Turblown
Vendor Classifieds
Oct 17, 2020 03:25 PM
LongDuck
Oct 7, 2015 08:12 PM
James Knox
Oct 5, 2015 07:56 AM
