no high end power
Old Apr 16, 2003 | 04:43 PM
Forgie's Avatar
no high end power
I keep hearing everyone say that the rx7 developes most of it's power at high rpm. for whatever reason my car seems to have most of it's power from about 3000 - 5000, does this mean something might not be working properly
Old Apr 16, 2003 | 04:47 PM
Randy Nix's Avatar
I wonder if the secondaries on the carb are opening, the vacuum thing that operates them might be broken. Search on mechanical secondaries. Your power shouldn't even start good till about 4K. Mine pulls really strong when the secondaries open up. I take it to 7-8K most every day.
Old Apr 16, 2003 | 05:14 PM
eddierotary's Avatar
back with rotaries
check youre catalitic converter. my friend had this problem and it was that.
Old Apr 17, 2003 | 09:56 AM
nlc1179's Avatar
do you have a gsl-se? if you do, make sure your 5th and 6th ports are opening. i had the same problem as you, and sure enough, my ports weren't opening. it makes a big difference. if you have a carb.....i dunno.
Old Apr 17, 2003 | 12:15 PM
jeremy's Avatar
male stripper
his is an 83. i'd say carb's secondaries or cat. if you are in a no emissions area i'd say gut the cat first as at least its out of the equation and it removes exhaust flow restriction.
Queppa
Nov 18, 2024 03:47 AM
distr0
Megasquirt Forum
48
Mar 18, 2022 06:17 PM
Th0m4s
Feb 26, 2019 02:04 AM
C. Ludwig
Jan 30, 2019 06:31 AM
