Washer Tank Removal?
Old Apr 16, 2003 | 01:19 AM
radkins's Avatar
How do you remove the windshield washer tank? It looks like you either have to remove the headlight, or maybe get to it from the bottom. The manual doesn't really tell you how to get it out, just where it is, unless I'm missing something.
Old Apr 16, 2003 | 01:31 AM
eric e's Avatar
new to the car so please excuse if incorrect
but if it's the bottle on the left side of the car i think removing the left front wheel and then the plastic wheel arch will allow you to get to the base of the washer bottle and the motor
at least it looked that way last weekend when i had that arch off to get in there for another reason
eric e
Old Apr 16, 2003 | 10:37 AM
HeatTreated's Avatar
Hi Powr FD's
Do what I did and make it an IC sprayer.
Just need about 4' feet of vacuum hose.
-unhook the stock windshield sprayer and attach the 4' vacuum hose and run it down to the IC. *if you can get a stock spray nossle it will work better. (I just have the hose aimed at the middle of the IC and go through about 1 quart a night of racing.) Also its good at keeping the intake charge cooler for hot city driving.
::Home Depot Racing Club::
Old Apr 16, 2003 | 11:37 AM
TwinTurbo93's Avatar
0-rotor-0-turbo-0-fd
I removed mines last week, its been alomost a year that I got a lilte hole in it so I finaly fixed it .
Just turn you wheels right all the way and take it out from under the car, don't remember the size of the wrench, not hard at all.
It would be good if you jack it up a litle.
Hope this helps you.
Old Apr 16, 2003 | 12:32 PM
apneablue's Avatar
It's very accessible after you remove the drivers side fender well cover.
Old Apr 16, 2003 | 06:43 PM
xstacy7's Avatar
I love when things work
hmmm, i may have to join the Home Depot Racing Club, sounds like a good idea. Where did you have them mounted?
Old Apr 16, 2003 | 09:55 PM
Donovan's Avatar
Hi sir
I took mine out. ( as well as the wiper motor and the wiper linkage and obviously the wipers too) I used the fender well method.
Old Apr 17, 2003 | 12:14 AM
radkins's Avatar
Actually the reason I need to remove it is I am building a fogger/cooler for the radiator and IC for the track. It needs to be a high pressure sysem to produce the fog/mist, so I am using my old stock fuel pump wich must sit in the washer tank. The system has 3 fogger nozzles on the radiator and 1 on the IC and will be activated by either a switch in the cockpit or by thermost.
Old Apr 17, 2003 | 02:27 AM
suprfast's Avatar
how did i know donovan would reply. i might try that intercooler mod from home depot. sounds like it may work for something, maybe drag racing if anything. now to the drawing board.
kris
Old Apr 17, 2003 | 10:46 AM
Hi Powr FD's
Oh yeah, I forgot to add that you will want to un-hook the windshield wipers so no one nows your spraying at the line. (the clip is on the passenger side right on the firewall, blue and black.. just unhook it and you can spray your IC with out the blades moving.)
*note that the fluid bottle for the wipers holds 2.2 quarts... of Ice water that is
Old Apr 17, 2003 | 11:04 AM
apneablue's Avatar
can someone enlighten me on this home depot IC mist thing from the washer tank?
Old Apr 17, 2003 | 11:28 AM
apneablue's Avatar
You know, I think I may try this but have a "Y" valve where I can switch to the windshield washer if I want and not have it totally disabled...
What do you put on the end of the hose to make it mist?
Old Apr 17, 2003 | 11:54 AM
Hi Powr FD's
Apnea,
You can even use any nossle spayer off any car too get a dual spray.
I tried the 'Y' valve, not enough pressure to push it through both. Plus you wont want the wipers to come on. If you leave the stock setup alone but disconnected, and run the 4' hose to the outlet, you'll have just enough pressure to spray the IC.
*ps. I registered on Tulsa Turbo but it wont let me post. Just put a thread on the South Forum here and Im sure about 6 FDs and a few FCs can make it up.
-Erick
Old Apr 17, 2003 | 11:59 AM
apneablue's Avatar
Sweet dude...This weekend I am helping two other FD guys here in town do the tail light mod...Going to go visit the south forum now...
- David
BLK 93
11
Sep 9, 2015 10:56 AM
risingsunroof82
Sep 7, 2015 01:11 PM
