best way to tighten belts?
Old Aug 27, 2001 | 02:14 AM
cpt_gloval's Avatar
KARATE EXPLOSION
my alt belt squeaks like a mother, especially during those redline shifts... how would i go about tightening that mother?
Old Aug 27, 2001 | 02:54 AM
Viperx7's Avatar
How old is the belt? I've found that some belts start to sqeak when they get old and some just seem like they naturally squeak. Does get annoying.
Usually on tightening, I get a big breaker bar or long extention for a socket, push it up and tighten it up.
Old Aug 27, 2001 | 07:40 AM
Denny's Avatar
Check for cracks on the underside of the belt (the side running against the pulley). Belts sometimes wear into the "vee" of the pulley leaving only the edges of the belt getting the traction, then they can start to squeal.
Denny, from the 'ol corncrib...
Old Aug 27, 2001 | 12:41 PM
rotorhead's Avatar
are you still running the emissions pump? if not, then that could be your problem. without it, it's tough to get the tension you need on that belt causing it to squeal at the water pump(not the alt). so far as i know, the only fix is a double pulley to give the belts more area to "grab".
Old Aug 29, 2001 | 12:13 PM
Jeff20B's Avatar
Lapping = Fapping
The clutch fan could be bad. Mine was and still squealed the belts with a dual sheave pulley.
Turblown
Vendor Classifieds
Oct 17, 2020 03:25 PM
Robrods64
Oct 2, 2015 07:56 PM
Turblown
Sep 30, 2015 05:58 PM
