boost?
Old Apr 15, 2003 | 11:23 AM
Smile boost?
i was wondering how can i turn up my boost. do i need an ecu upgrade or can i just get a boost control. or do i need both.
Old Apr 15, 2003 | 11:26 AM
neoamd's Avatar
LS Powered
depends no your mods man.
I would reccomend a cb, dp, mp, I/C, ECU, Fuel pump, and bigger injectors. I would run 12-14lbs. For a boost controller I went with a Manual one. You can also spend some extra money and get a electronic one like a Profec B or SBC-ID
Old Apr 15, 2003 | 11:36 AM
Shinobi-X's Avatar
Sensory Experience
Depends on your mods. If you have the basic bolt-ons, it's a better idea to have the appropriate fuel (upgraded fuel pump, ECU, and injectors) to balance out the added boost, or else you may run lean. If you don't have the standard bolt ons, an intake, downpipe, and exhaust, along with the above mods would be able to safely put you around 12psi, depending on your choice of setup. A boost controller would just be a way of...well, controlling the boost setting, but unless you have the mods, it wouldn't be wise to raise boost simply by itself.
Shainiac
Jul 17, 2019 02:20 PM
Bauer778
Nov 4, 2015 04:42 PM
zxrazorxz
Sep 14, 2015 07:21 PM
High_Carb_Diet
Power FC Forum
Sep 5, 2015 09:07 AM
