Inspection
Old Apr 10, 2003 | 06:59 PM
brianmcd's Avatar
Question Inspection
Hi, I'm looking into what to do with my car, but one of the major problems I'm having is finding things that will pass inspection. What do you guys do who have exhausts with no emissions or any other mods that don't normally pass inspection? Bribe? I'm in central virginia, and the inspection process isn't that hardcore, just a visual check for a cat, no smog sensors or anything. So what do you do? I'm wondering if I should go down the emissionsless path and pray, or go (slowly) down the legal way. Thanks guys.
~brian
Old Apr 10, 2003 | 07:53 PM
brianmcd's Avatar
Help? Anyone? Please?
Old Apr 10, 2003 | 07:59 PM
1984special's Avatar
So little time and money
Well, you could just replace all the performance stuff with the smog OEM stuff everytime you need to get a smogcheck (every 2 years in CA). Of course this is labor intensive and a real pita. Or you could pay a shop to do this but that's $$$. CA is realll strict about emissions so that's basically what you have to do here in order to pass smog.
Old Apr 10, 2003 | 08:08 PM
brianmcd's Avatar
Here they just do a visual check for a cat, I think. No smog sniffer or anything.
Old Apr 10, 2003 | 08:14 PM
Sammymatik's Avatar
What about the SA's with no cat? I wonder if they would give a hassle about that?
Old Apr 10, 2003 | 08:21 PM
brianmcd's Avatar
In va, cars that are 25 years or older don't have to pass inspection. Aside from that, I don't think there are any other exemptions.
Old Apr 10, 2003 | 08:28 PM
brownmound's Avatar
Anytime baby!
Here in Austin they (very surprisingly, though I'm sure it's coming soon) do not do emissions testing. I have the RB system (no cats). Last time I went to get it checked I went in with $50 in my pocket. I told em I need a test, 10 minutes later he pulled it around, said, "All done." $12 and I was out the door.
My car stinked of gas horribly, and I think he had it on the lift....no way he didn't know...so you just have to find the right shop. Ask around.
Right on.
Old Apr 10, 2003 | 08:29 PM
82transam's Avatar
Never Follow
if its just a visual then hollow the cat out. run a header, go all out if you want.
Old Apr 10, 2003 | 08:38 PM
brianmcd's Avatar
I've been talking with onepointone a lot tonight about exhaust stuff. I think I'm gonna get the $527 system from racingbeat, then get a shop to put a cat where the connecting pipe is. I'll probably hollow the cat out after I get the shop to put it in. Does hollowing out the cat give you much HP as opposed to if I had the system and all but didn't hollow out the cat? Thanks guys, I really appreciate all of your help/responses.
~brian
Old Apr 10, 2003 | 09:15 PM
82transam's Avatar
Never Follow
if your going to buy a new cat i wouldn't hollow it. Modern cats are pretty good for power, the gains would be mininal.
Old Apr 10, 2003 | 09:24 PM
brianmcd's Avatar
Ok, I won't hollow it then. Thx! With this setup, with the new cat and all, do you think I'd pass a smog test? (even though we don't require it here yet)
Old Apr 10, 2003 | 10:03 PM
jerij's Avatar
I smogged mine 2 days ago. Passed beautifully. RB header, Catco hi-flo, Rotary Performance muffler, rat's nest/ACV intact, timing to spec(Mazda's).
Find out what Va checks for and rebuild accordingly. After you pass, you can then "re"-rebuild.
jerij
Old Apr 10, 2003 | 10:12 PM
buddah9543's Avatar
here in NY i bribe someone only 60 bucks. A normal inspection is like 40 so it ain't so bad.
Old Apr 10, 2003 | 10:15 PM
82transam's Avatar
Never Follow
hey jerij: do you happen to have the numbers handy? NJ checks for NOx, CO2 and HC's, what were yours? I'm curious to see if it would pass here. thanks
Old Apr 10, 2003 | 11:54 PM
bliffle's Avatar
Put the cat in. These things have improved ENORMOUSLY in 18 years.
B
Old Apr 11, 2003 | 12:01 AM
wwilliam54's Avatar
it WILL run
take a old stock cat and cut out a stip on the top that is wider that the exuast pipe
take everything out and set the exuast pipe into the space you cut into the cat
weld the pecie you cut off back on and then weld the ends of the cat shell to the exuast pipe
should pass visual
Old Apr 11, 2003 | 04:17 AM
jerij's Avatar
HC = 1 LIMIT=220
CO = 0% LIMIT = 1.5%
NOX = NOT TESTED
CAT = PRESENT
jerij
Old Apr 11, 2003 | 11:12 AM
bobbitt's Avatar
Holy shnikeys, $40 in NY...how the hell is everyone advertising NYS Inspects for $10.00?
Old Apr 11, 2003 | 11:35 AM
82transam's Avatar
Never Follow
private inspection here can be as low as $30 and as high as $97. oh well, another perk of working at a gas station, i get it for free.
jdayau
Nov 29, 2019 12:11 AM
Coochas
44
Nov 5, 2019 11:08 PM
Sethix
Nov 3, 2017 11:48 PM
t-von
Sep 10, 2015 01:56 PM
