My New Best 1/8 Mile
Old Apr 10, 2003 | 04:00 PM
Roy Johnson Jr's Avatar
Boost Feels Good
I bought me some ET streets and headed to the track the other day. I'm running 17 psi on my T-78, which put down 440 rwhp. My driving is not to be envied. I need to work on my shifting and launching real bad. Mod list can be seen at www.royjohnsonjr.com .
My 60' was a 1.69 and I ran a 7.37 @ 93 mph. My mph is low due to my tuning only going to 7200 rpm (don't ask why, I don't know ). In a few months, I plan to install my 3 bar map and turn the boost up to around 25 psi. I'd like to get the car in the 6s.
Old Apr 10, 2003 | 06:23 PM
93 R1's Avatar
Not bad
Old Apr 10, 2003 | 08:23 PM
crispeed's Avatar
'Tuna'
7.37 is a pretty good 1/8th mile time.
Should go mid to low 11's in the 1/4.
crispeed
87 Rx-7 TII
9.204@150.47mph
2600lbs
un-tubbed
Old Apr 11, 2003 | 12:29 PM
SPOautos's Avatar
Hey, where did my $$$ go?
If your making 440 on the dyno at 17psi your tuning cant be that bad.....unless you changed it
Anyway, nice numbers.....your 93mph is pretty low for that 7.3 et. You sure it wasnt closer to 98mph? Especially with that 60 foot time.
STEPHEN
Old Apr 11, 2003 | 12:38 PM
vosko's Avatar
Just Call Me Terminator!
that is pretty damn good
here is my best et from last year
rt .765
60" 1.773
330 5.043
1/8 7.793
MPH 91.67
1000 10.070
1/4 12.011
MPH 116.65
Old Apr 11, 2003 | 05:11 PM
Boost Feels Good
STEPHEN
I was shifting at 7,500 rpms because if I run it to redline, the mph drops down to around 90 mph. For some reason, when my tuner worked on my car, he stopped the pulls at 7,200 rpm??? I believe the mph would be better if I could carry the rpms to 9,000. The car was still making power when he let out at 7,200. You can see my dyno graphs (the graph on the bottom of the page is what I'm running on) at:
Roy's Dyno Graphs
Old Apr 11, 2003 | 06:10 PM
Scalliwag's Avatar
WingmaN
What track do you run at?
Old Apr 14, 2003 | 03:51 PM
Boost Feels Good
Brainerd Dragstrip (1/8 mile) is about 15 minutes from my house. I go to Steele, AL to run the 1/4. It is about 1 1/2 hours from where I live.
Old Apr 14, 2003 | 05:24 PM
BDC's Avatar
BDC
BDC Motorsports
Way good 8th mi run, Roy, but like another poster said, the trap is pretty low for the ET. What kind of slicks were you running?
B
Old Apr 14, 2003 | 10:31 PM
Boost Feels Good
B
Mickey Thompson ET streets. 26 x 11.5 x 16 (on the stock rims).
Old Apr 14, 2003 | 11:08 PM
i just ran an 8.35@93. also a street ported t78 car. i was on crappy 245/45/16 sumitomos and they werent even the sticky sumitomos so i had a 2.35 60ft(worst in my life with any car lol and this is my highest power-to-weight car i have ever owned although i have had higehr hp before) and i also kept destroying my tranny and tried to make the 2nd to 5th shift and gridn that ahrd and then finally went to third so i could probably expect a few more mph and a WAY lower et with some tires and better shifting.
Old Apr 15, 2003 | 05:58 PM
SPOautos's Avatar
Roy, I didnt know you were that close to me....do you actually go to Steele sometimes??? If you ever go you should PM me and I can try to meet you there, its only 30 minutes from my place. Also, if I ever go I'll PM you to let you know in case you can make it but its usually a spurt of the moment kinda thing for me. Friends call me on thier way to the track to tell me they're going so I jump in the car and go...that kinda thing.
Anyway, we should meet up sometime for that.
Also, I still say something doesnt sound quite right....you ET sounds fine but short shifting or not your mph should be like 98 or so. I ran 8.0 @ 92ish with a 1.89 60 foot. Its just wierd...maybe its the slicks throwing off your mph.
BTW - what rearend you running???
STEPHEN
Old Apr 15, 2003 | 09:17 PM
Boost Feels Good
STEPHEN
That's cool. I will let you know the next time I am going.
What is your best 1/4 mile?
I cached out my stock rearend at Steele. I have the KAAZ LSD now.
Glazedham42
May 2, 2022 02:41 PM
NCross
Aug 29, 2015 01:55 PM
Nuvolari
NE RX-7 Forum
Aug 24, 2015 09:44 AM
20B Forum
Aug 18, 2015 02:46 PM
