13b powerband?
Old Apr 9, 2003 | 08:40 PM
O 16581 72452 5's Avatar
The infamous number guy!
13b powerband?
So is the power band on the 6 port 13b the same as the 12a? does wiring the ports open change the powerband any.... where is it recommended to shift for manimum acceleration?
Old Apr 9, 2003 | 08:41 PM
maximum... i mean
Old Apr 9, 2003 | 08:51 PM
nlc1179's Avatar
the powerband starts at about 3500 to 3900. wiring the ports open will give you a little less torque in the low rpm's, but the powerband doesn't change. you should probably shift around the redline.
Old Apr 9, 2003 | 08:55 PM
I shift when i hear the buzzer, but i hear the power doesn't start dropping until around 8k.
Old Apr 9, 2003 | 09:24 PM
Manntis's Avatar
add to cart
Max torque comes on at about 2700 and stays on until redline. That's what makes the 13B such an engineer's dream come true.
Old Apr 9, 2003 | 09:44 PM
WackyRotary's Avatar
standard combustion
I still think my FC n/a -with headers/no cats/air filter/airpump running 5/6ports doesn't make enough power below 2000rpm though. Above 2000rpm-7500rpm is fine though. I drove a couple GSL-SE's and found the same issue. However, who am i to complain when a bridgeport 12a I have doesn't make any power below 4000rpm. But then it makes way more from 5000-9000rpm then my FC.
LongDuck
Oct 7, 2015 08:12 PM
spokanerxdude
Megasquirt Forum
Oct 6, 2015 12:28 PM
Robrods64
Oct 2, 2015 07:56 PM
Boans
V-8 Powered RX-7's
Sep 25, 2015 04:34 PM
