Need some input on what this problem might be?
Old Apr 9, 2003 | 07:28 PM
Rx7aholic's Avatar
Hey I trying to help out some thru a phone. Anyway he has a 93 with oem precat and main cat,66.000 miles on the car. Here is the problem when the car comes a stop a light or etc and he put the car in gear the idle hunts above 1,000 rpm? The car start fine boost fine and idle fine a little over 800 rpm. I am thinking of a switch that behind the clutch pedal? Can anyone correct me if I am wrong or what other problems his car can be having? thanks alot, khris
Old Apr 9, 2003 | 10:58 PM
cewrx7r1's Avatar
Eye In The Sky
There are two clutch switches, one for the starter and one for the ecu. The ecu one can cause idleing problems if not working. So can a bad or misadjusted TPS, or O2 sensor, or too much idle air that the ISC solenoid can control. Leaking vacuum hose or gaskets can too.
Many things to check.
R.O.D
34
Jan 6, 2016 12:09 AM
ZacMan
Sep 19, 2015 09:20 PM
The1Sun
Sep 18, 2015 07:13 PM
localized
Sep 16, 2015 12:18 AM
The1Sun
Sep 15, 2015 04:45 PM
