Sponsored by: CARiD
replacing auto engine with MT engine
Old Apr 7, 2003 | 06:41 PM
COsborne's Avatar
My Custom Title > Your's
I bought an auto rx7 with intentions of swapping to a MT. On the way home from buying it the engine blew though and now I am swapping an engine instead of transmission. I am buying an engine from a manual transmission equipped car. Do I have to replace the counter balance in the manual engine with the counterbalance from the auto engine?
Old Apr 8, 2003 | 02:26 PM
Cosmo Donk's Avatar
Queer
Well, here is what I have found...
If swapping same year engines then you must attach the auto counterweight with the auto flexplate (the thing that the tranny hooks onto). This will replace the flywheel/counterweight assembly of the MT engine.
Old Apr 8, 2003 | 04:14 PM
COsborne's Avatar
k so that sounds like a yes I have to pull off the front cover then...
Old Apr 9, 2003 | 10:15 AM
Cosmo Donk's Avatar
Queer
Hmm. Maybe I was a little confusing. I am pretty sure that if the engine is the same you can just swap the rear counterweight and flexplate in place of the flywheel/counterweight assembly.
I talked to a bunch of people about this when I put my Cosmo in because I was trying to figure out what flywheel to use. I ended up using my auto tranny counterweight with a lightweight flywheel so it should be the same in your situation, except you are going the other way.
Old Apr 21, 2003 | 11:48 PM
COsborne's Avatar
guess what...cant do it... everything bolts up great except the auto starter... Oh well Im screwed
Old Apr 22, 2003 | 01:30 AM
rxtasy3's Avatar
Well of course u have to get a starter for a manual tranny.
Old Apr 22, 2003 | 01:31 AM
COsborne's Avatar
manual starter wont do me any good with an auto transmission. I'm locating the parts right now. Found good deals on most of the main stuff. Youre welcome to come install it all
Old Apr 22, 2003 | 10:10 AM
rxtasy3's Avatar
Sorry, I thought u were doing the manual swap.
GrossPolluter
Aug 16, 2015 09:50 AM
