EGT and Water temp Readings help
Old Aug 25, 2001 | 02:09 PM
Rotormania's Avatar
I’m planning to install an EGT gauge. Can you guys tell me what temperature reading are you getting during idle and full throttle?
Also what is a “normal” water temperature that you are getting from your water temp gauge (aftermarket gauge)? I get readings little below the middle but when I turn the engine off I hear bubbles in the Air Separator Tank.
Old Aug 26, 2001 | 10:03 PM
alwan16's Avatar
Re: EGT and Water temp Readings help
450C idle
650C freeway
??? full throttle though i've never seen past 650.
sensor is on downpipe near turbo
anywhere from 82C to 110C
usually 85C-95C in city
i have a fluidyne radiator and the sensor is in the stock location.
sherff
Feb 24, 2019 12:09 PM
yetter227
20
Sep 5, 2015 11:57 PM
befarrer
Microtech
Aug 22, 2015 05:52 PM
