How Do I Remove My Motor Mounts?
Old Apr 5, 2003 | 08:11 PM
Broken.Control.Arm's Avatar
Newbie
Exclamation How Do I Remove My Motor Mounts?
I can't seem to get them off. I've tried to get them off with a wrench. I might just drill them off. What do I do????
Old Apr 5, 2003 | 08:44 PM
alwan16's Avatar
try a big breaker bar and some pb blaster too. that should work.
Old Apr 5, 2003 | 09:26 PM
PureMdMa's Avatar
1 of 203 94 White PEP's
Air wrench works great.
Old Apr 5, 2003 | 09:52 PM
cewrx7r1's Avatar
Eye In The Sky
I have helped pull over 6 engines and never had any problems with motor mounts. The e-shaft front bolt
is the only thing to ever give us problems.
You are using a 3/8 or 1/2 torque wrench or breaker bar,
with socket, aren't you?
Using a box end wrench is being uneducated.
Old Apr 6, 2003 | 12:50 AM
xstacy7's Avatar
I love when things work
lefty lucie, righty tighty
Old Apr 7, 2003 | 01:03 AM
Fd3BOOST's Avatar
Recovering Milkaholic
I agree pb blaster and a torque wrench.
Oh and make sure that the engine is out of the car LOL
Old Apr 7, 2003 | 12:02 PM
cewrx7r1's Avatar
Eye In The Sky
The engine does not have to be out of the car.
We pull the motor mounts before pulling the engine as it gives about 4" more room.
Same applies for putting the engine back in. Easier with the mounts off.
Old Apr 7, 2003 | 05:43 PM
apeiron
yea man, breaker bar
Old Apr 7, 2003 | 09:49 PM
if you cant losen the mounts with a breaker bar heat up the nut with a torch. i hope your talking about the nut that is tightened to the sub chasie. if you cant losen the mounts from the motor they were over tightened they arent suposed to be that tight.
