Tach is pegged, does not move!
Old Apr 4, 2003 | 01:35 PM
cover8's Avatar
Unhappy Tach is pegged, does not move!
Ok, here we go again! The tach needle is all the way pegged...car idles fine but does not even move the needle. I know these tachs are fragile...dont think it is disconnected, but what gives?
Do I have to remove the tach and carefully move the needle back to the zero spot? Does this sgnify another grand repair on the seven?
Old Apr 4, 2003 | 04:40 PM
RonKMiller's Avatar
Blow up or win
Damn......turn that engine off RIGHT NOW or you'll blow it!!!!
Four options that come to mind from cheapest to most expensive: (although if you try you can probably spend more)
See if you can reset it with a drop of Super Glue. Hopefully the needle has just slipped and the tach
still functions. OR.....
A trip to the junkyard is in order - to find another instrument cluster and gut it for the parts. OR...
Call Ray at Malloy Mazda - 1-888-533-3400. He'll get you the lowest price on a new OEM one. Typically 30 - 40% off retail. OR...
You can always get a new RE white face cluster from J-T Imports for $1395.00. You'll impress your friends with it's 10,000 rpm redline and 300 kph max speed!
Good luck!
Old Apr 4, 2003 | 05:56 PM
adam c's Avatar
Cheap Bastard
I had an oil temp sensor wire that got fried. It got on something hot, and grounded/melted. The gauge went to the highest reading, and just stayed there. You may have the same problem. Check your wires before spending a bunch of time/money on a replacement.
Old Apr 4, 2003 | 08:45 PM
cournal's Avatar
in the past i have seen tachs get stuck or pegged. the fix was to start the car, in nuetral bring the idle up to about the middle of the gauge or a bit higher and shut the car off. sounds a bit odd but i have fixed about 5 tachs in that manner (they were not rx7s but they were all mazdas)
Old Apr 5, 2003 | 03:47 PM
RonKMiller's Avatar
Blow up or win
Good point - I am assuming he would check continuity first.....
Robrods64
Oct 2, 2015 07:56 PM
Thor 18
Sep 28, 2015 07:35 PM
subeone
Sep 24, 2015 09:58 PM
