BLEEDING wasn't hard!!!!
Old Apr 3, 2003 | 06:44 PM
MRGSL-SE's Avatar
ROTOR THAT PUSSY BITCH
I completed a CLUTCH MASTER CYLINDER change up in 3 hours... it would have been 45 mins... but had to do something else too.... I did it one person bleeding job.... my clutch feels STRONGER than ever....
Don't forget SOCAL members meet up at Parking Lot C on Museum.... Can't wait to see y'all.... the last time I showed up.... my BROTHER drove me in his 1999 CIVIC EX.... so embarrassed.... finally.... my GSL-SE is Environmentally friendly...... but I won't be able to cruise with y'all.... gas is expensive for a college student....
Old Apr 3, 2003 | 06:47 PM
Sammymatik's Avatar
Who ever said bleeding a clutch cylinder was hard!?
ANd what are we meeting up for exactly? And where are you talkin bout?
Old Apr 3, 2003 | 09:45 PM
MRGSL-SE's Avatar
Are you a member of SOCAL Rx-7 club??? www.socal7s.org.... you'd know what i'm talking about.... besides... I've never bled anything before....
Old Apr 3, 2003 | 11:31 PM
Sammymatik's Avatar
I'm not a member.
And bleeding something is no problem. As long as there are no leeches involved!
Old Apr 4, 2003 | 12:22 AM
MRGSL-SE's Avatar
oops my bad
www.socal7s.org
post prosti
Old Apr 4, 2003 | 09:57 AM
MRGSL-SE's Avatar
hood rat posting ..... can't get enough....
here I come 1000 posts...
Old Apr 4, 2003 | 11:01 PM
vipernicus42's Avatar
Rotoholic Moderookie
Yeah, my friend Michel and I looked at the clutch on the old car... it stuck to the floor when you pushed it.. we checked the fluid, the disc had been changed 4 years ago so we're like "alrighty, let's change the master clutch cyl!"
so we did.. and it popped up and worked... three, four pumps... then it lost pressure again.... so it was *half* working.. so back to the partyard we go. Get a rebuild release cyl too, change THAT.... two days, finally got the clutch...
And it still won't run because of the carb problems! wish me luck guys, if my godfather doesn't hold out on me this weekend, I will be rebuilding the carb all sunday... after that it's installation, brakes, gas, coolant and trying to get it saftied!
Old Apr 5, 2003 | 11:15 AM
MRGSL-SE's Avatar
GOOD LUCK!!! Make sure the Slave cylinder bleeding nipple is tightly closed.... and the metal connection that connects the master cylinder to the slave is tight.... It'll leak fluid if not....
Old Apr 5, 2003 | 11:25 AM
bliffle's Avatar
One time I stupidly replaced the clutch master cyl and it turned out the little footlong hose was leaking. Lot's easier to replace the hose IF you dope it out right in the first place.
B
Old Apr 5, 2003 | 08:19 PM
Hyper4mance2k's Avatar
The Shadetree Project
one man bleeding how is that possible??
Old Apr 5, 2003 | 09:22 PM
bliffle's Avatar
Glass jar and hose. Check valve optional.
B
Old Apr 5, 2003 | 09:34 PM
81Rex6port13b's Avatar
I Push My Car Real Fast!
VB sells a littel pump thing that lets you do one man bleeding. if you want to spend the money on it.
or you could do:
Pumpx10 > jam a peice of wood in there to hold the pettal down
Old Apr 6, 2003 | 12:48 PM
bliffle's Avatar
I've done it with the board, too.
I think there's also an aftermarket bleed valve replacement with a builtin checkvalve. But who needs it, if you've got a 2x4 handy, or a jar and hose?
B
Shainiac
Jul 17, 2019 02:20 PM
teebeekay
Sep 16, 2015 01:54 PM
