Boost Problem theory
Old Apr 1, 2003 | 11:35 AM
M. F. Luder's Avatar
Hi All,
After do some searching on Boost problems here, I am thingking that I need to replace my Turbo control actuator & my change control valve. I am getting no boost at WOT in any gear. I get 10psi when not under heavy load with the first turbo, but it usually drops to nothing when shifting gears & I get this awful sound that I can't even describe. Boost drops right off when I get to 45K rpm & doesn't come back.
I just had the hose jobs done at BPR, and while I would have this problem only slightly before then, it is much more pronounced now.
so how's my logic? Any onter ideas besides going single or non-seq? Thanks in advance for the help.
ME.
check sig for mods.
Old Apr 1, 2003 | 11:37 AM
Doesn't appear that sig showed up, so here are the mods:
M2 Dp
RE Air Intake
silicone hoses
Catback exhaust ( was on car when I bought it, don't know who makes it).
Old Apr 1, 2003 | 11:46 AM
adam c's Avatar
Cheap Bastard
Sounds like your vacuum hoses may not be right. I had a similar problem: Good primary boost, and no secondary boost. I found a loose vacuum hose under the intake manifold, behind the black pressure tank.
Hope that is your problem. It's an easy fix.
Adam
Old Apr 1, 2003 | 11:48 AM
Thanks, I'll have a look, but I don't think that explains the lack of boost from the 1st turbo at WOT & that annoying noise that accompanies it.
Old Apr 1, 2003 | 02:10 PM
anyone... Bueller... anyone...
Old Apr 2, 2003 | 01:03 AM
Bucrx7's Avatar
Do you get boost from the primary turbo when your at WOT? Is your boost pattern something like 10-8-2 or close?
Old Apr 2, 2003 | 07:14 AM
If I start from a dead stop & jump on it, I get no boost at all, but if I rev up slowly, I get 10psi on turbo 1 all the way up to 45K when the CCA tries to kick in turbo 2, then boost drops to zero. If I stay in the throttle, it boost will sometimes come back to ablut 5-7psi, but thats it.
Old Apr 2, 2003 | 08:08 AM
911GT2's Avatar
The Power of 1.3
Sounds to me like symptoms of TCA or one of the check valves that go with it. It opens, but not as quick as it needs to, so you get a slow build of boost instead of the quick recovery that you're supposed to get.
Have you looked at this page?
http://www.autosportracetech.com/RX-...leshooting.htm
Lots of good info there if you haven't seen it yet.
Old Apr 2, 2003 | 11:53 AM
Thanks 911, I have seen this document, but will go through it thourghly this weekend. Anyone have any idea how much a Turbo Control Actuator & Charge Control Actuator cost?
rgordon1979
40
Mar 15, 2022 12:04 PM
sherff
Sep 12, 2015 12:22 PM
AXA
Sep 5, 2015 10:06 AM
tiger18
Sep 3, 2015 08:27 PM
rx7shirley
Sep 2, 2015 02:11 PM
