Throttle Position Sensor
Old Mar 31, 2003 | 12:56 AM
Garrett's Avatar
I broke the connection to my TPS during the Vacuum Hose job and am going to order a new one.
How do you set it in the Throttle body? I've talked with someone already and he said the two prongs that stick out on the TB itself have to be pushed into the plastic connector. Then the sensor has to be adjusted after you have it on by keeping the screws loose. Is there a procedure in the factory manual that I am missing? How do you get it on without messing anything up?
Old Mar 31, 2003 | 01:47 AM
dznutzuk's Avatar
Uncontrollable drifter
Once you inscrew it you mess up the settings and have to calibrate it
Old Mar 31, 2003 | 11:39 AM
duboisr's Avatar
BS --You do not press it in to the anything.. Easy it just sets beside the two flats that rotate it . It returns on its own spring, just look for your self . If you press it to the metal you will break a $150 part. This is not hard to look at and reason out.
Old Mar 31, 2003 | 01:10 PM
damian's Avatar
DDH Motorsports
Top Answer: 1
look at this thread for a link on how to adjust the TPS:
https://www.rx7club.com/forum/showth...hreadid=170731
barkz
Power FC Forum
37
Nov 21, 2020 09:34 AM
