Gearbox Question
Old Mar 27, 2003 | 05:41 AM
karism's Avatar
Adolf Hitler Verfechter
Arrow Gearbox Question
So i stuffed the selector fork on my gearbox.
Does anyone know if the internals of the B2200 Mazda trucks are the same ?Also would i be able to fit a B2200 one,and will it be stronger?
I have the bad habbit of bending selector forks.
All input will be appreciated !
K
Old Mar 27, 2003 | 10:50 AM
Pedestrian X's Avatar
SpAz!
just try not to shift so mad quick y0!
Old Mar 27, 2003 | 12:49 PM
peejay's Avatar
Old [Sch|F]ool
Should be the same internally. Just swap the front and rear housings off of your RX-7 trans onto the B2200 trans.
Make sure that the shaft lengths are the same, first. Some trans had a different length input shaft, so be careful.
It won't be any stronger. Personally due to the gear ratio differences I'd just use the B2200 trans for the parts needed to repair the RX-7 trans.
_Tones_
May 25, 2021 05:37 AM
Nosferatu
Sep 5, 2015 02:13 PM
