15 lbs?
Old Mar 26, 2003 | 07:43 PM
BLKTOPTRVL's Avatar
15 lbs?
Went out tonight, was playing with an acura for a little while, hit the gas and noticed that when first floored, the boost reached 15 lbs. Then it backs down to 10-12 lbs.
If I open the throttle more slowly, the boost peaks at 10. I think I will buy a boost controller soon.
But I was wondering if the warmer weather (this is the first really warm day of the spring - prior to now the temp was hovering around 60 degrees) allows the turbos to create more boost?
Any thoughts about the sudden increase in boost?
As I said, this was the first really warm day and prior to now, I was only maxing at 12 lbs.
Also, this weekend I took off and reinstalled the intercooler to tb hose. Perhaps this could be a sign of a boost leak?
Old Mar 26, 2003 | 07:45 PM
ttb's Avatar
ttb
No Cup Holder Racing
i think it's harder to control boost when the weather is colder, not warmer.
Old Mar 26, 2003 | 08:10 PM
actionhank's Avatar
it is. Cooler air = more dense = usualy more boost. So be carful on cold days.
Old Mar 26, 2003 | 10:05 PM
twinturborx7pete's Avatar
Juris Doctor
sounds like you need that boost controller and possibly to port your wastegate....
Old Mar 27, 2003 | 08:31 PM
BLKTOPTRVL's Avatar
I've been thinking about it today...
Could the wastegate be sticking?
Or the pills choked?
Anything else that can push the boost high overnight?
Old Mar 27, 2003 | 08:53 PM
SnowmanSteiner's Avatar
Ga-nome liberator
What rpm range were you in? And where in sc do you live?
- Steiner
Old Mar 27, 2003 | 11:05 PM
insomniac's Avatar
I had the same problem using my blitz turbo timer with it's built in boost gauge.
I installed an Apex mechanic gauge. Then ran both of them at the same time. It seems like everytime I quickly floor it. The blitz will always read higher. The Apex was pretty consistant.
Borrow another gauge from a buddy and check it out.
Old Mar 29, 2003 | 09:39 AM
BLKTOPTRVL's Avatar
- Steiner
I can be almost anywhere in the RPM range... It only occurs when I go to instant WOT.
After looking closer at my gauge, I can also say that it is more line 13.5 to 14 lbs. As my gauge does not zero when the engine is off, it often shows 1 to 1.5 lbs at rest.
I live close to Columbia.
Old Mar 29, 2003 | 09:41 AM
BLKTOPTRVL's Avatar
Thanks, I'll see if I can find another.
It would be nice if the Profec B I am planning to purchase could also report boost history.
nycgps
30
Sep 29, 2015 12:02 AM
