where should the temp gauge sit?
Old Aug 23, 2001 | 02:21 AM
cpt_gloval's Avatar
KARATE EXPLOSION
I was wondering what the normal position for the temp gauge at normal operating temp...
Mine sits about a half a centimeter above the "c" line. after i flog it for a bit, it occasionally rises to about 1/4 of the way between "c" and "h".
Old Aug 23, 2001 | 02:34 AM
Felix Wankel's Avatar
Super Newbie
Mine is the same way.
My -SE sat a bit higher, almost halfway.
Old Aug 23, 2001 | 10:09 AM
P.O.S. Racing's Avatar
My –SE had always ran at ½ until this past Sunday, got a new and shinny radiator on the way!
Old Aug 23, 2001 | 11:03 AM
abeomid's Avatar
my -SE always sat around halfway until I got a new thermostat from Mazda and change the coolant, since then it always sits 1/4way and if i push it hard it goes to 1/3.
that's my 2 cents
Old Aug 23, 2001 | 03:00 PM
Sterling's Avatar
Nikki-Modder Rex-Rodder
On my 85 12A, it sits just below 1/2 way. I donlikit...It never seems to fluxuate, even when I'm romping on her. Can't be very accurate.
Old Aug 23, 2001 | 04:03 PM
Kerry's Avatar
Mine sits right between the oil pressure gauge and the tach.
(sorry, I just couldn't stand it any longer. it had to be said)
Kerry
Old Aug 23, 2001 | 04:27 PM
riffraff's Avatar
smog nazi destroyer
the stock ones are generally described as having the classic three position : cold, somewhat normal (or acceptable), and you just cooked your engine. so i would definatly not trust it for accuracy.
Snoopy FD
Dec 8, 2015 01:45 PM
josef 91 vert
Aug 29, 2015 12:22 AM
LMBTG
Aug 15, 2015 01:43 PM
