i want his hood, HELP!
Old Mar 22, 2003 | 04:15 PM
rollin82's Avatar
From: tucson, arizona (setting off car alarms daily) (whats a presilencer?)
ya i know you've all seen it at least at some point or another.....
Turbo II scoop on a 1st gen hood
i want it... i tried contacting mariah since they made one for the silver that silver GSL-SE turbo.... i even tried emailing the guy they made it for...
both of which i had no luck.....
ive seen atleast 5 different cars with this mod soo i know someone must have one to sell or will make it for me (i cant do body work worth a ****)
anyways id be reall nice if any of you guys could help me out
thanks
-shaun
Old Mar 22, 2003 | 04:48 PM
ummm Bern has the silver car with the hood you want... like my avatar
But , all I can suggest, is make one...... or pay some body shop too........ iiiick
Old Mar 22, 2003 | 05:07 PM
rollin82's Avatar
dammit i was afraid of that........ i dont like any of the local body shops here.................. plus just buyin one would be sooo much easier haha
Old Mar 22, 2003 | 05:20 PM
damn hippies
there are tons of scoops on ebay that could be bought....cut your hood and fiberglass it or bondo it..the most work is going to have it painted
Old Mar 22, 2003 | 06:50 PM
rollin82's Avatar
ya i know i shoudl just do it but....
anyone else have any knowledge on this
or knows of someone who has done it
Old Mar 23, 2003 | 08:59 AM
smile444's Avatar
Why do you want the scoop so bad? Appearance? Or are there performance benefits?
Old Mar 23, 2003 | 09:58 AM
there arent any benifits that i can see, ask Manntis......
Old Mar 23, 2003 | 10:04 AM
MikeLMR's Avatar
'Last Minute' Rallying
The TII hood is designed to flow air through the standard top mount intercooler , no intercooler on the 1st gen so all your really doing is raising the pressure in the engine bay and therfor reducing the flow through the rad + it will add some drag
Old Mar 23, 2003 | 10:47 AM
Narcisse91's Avatar
I could see some potential cold air intake applications that would be good for performance. If it was designed right...
Old Mar 23, 2003 | 10:58 AM
pvc's Avatar
pvc
Not a registered voter
But if you wanted it for a cold air application, wouldn't it be better arrow-dynamic-ly to have an air duct? (Sorry can't spell very well). (I'm not good with grammer either)
Like the mariah hood. Plus I think that hood looks better than the turbo II hood. At least, on a FB anyways.
Old Mar 23, 2003 | 11:09 AM
Narcisse91's Avatar
I honestly don't know which would be better, overall. The aerodynamics would be better with an air duct, but the the benefits of the scoop might outweigh that.
There are air filters for carbs that are designed to just have the most possible air flow. But they suck hot air from the top of the engine. If you put a scoop above it, you would have all the air you need, plus it would be colder.
A lot of muscle cars get set up kinda like this, but when you're making 400 lbs of torque at 2000 RPM, drag isn't really a concern.
Old Mar 23, 2003 | 06:40 PM
rollin82's Avatar
wow i leave this post for a day and all these repsonces....
anyways i wanted to get the hood becuase i honestly like the way it looks..... plus im thinking about rebuilding a TurboII turbo and exhaust manifold i have and then running a turbo II port matched intake manifold and IC............ soooooooooooooooo if i had the turboII hood scoop it would work out perfect (even thought the stock IC fora TII isnt all that great
but im all about spending the least amount of money possible haha plus still being lazy
but whatever
-shaun
Old Apr 8, 2003 | 06:08 PM
nosferatu595's Avatar
I have the answer. Contact this guy at CPRACING. They are in the process of making an all glass 1st gen hood with the TII scoop already on it.
Christopher Campitelli, C.O.O
CP RACING & DESIGNS
19 Robb blvd Unit 3
Orangeville, Ontario
L9W 3L1
519-940-9225
Don
Old Apr 9, 2003 | 06:54 PM
update. They can ship you just the scoop to glass onto your hood for @75.00!!! I asked when I called them about my body kit today.
Old Apr 10, 2003 | 03:27 AM
Bern's Avatar
Re: i want his hood, HELP!
Originally posted by rollin82
<snip>
-shaun
Shaun,
How's it going? I'm a little concerned here... you say you tried to contact me and Mariah on this and had no luck?!? I checked my e-mail and I didn't see an e-mail from you... when did you write?
As for Mariah, I checked with them and they did acknowledge recieving an e-mail from you on 02/09 and responding to you on 02/17, to the following e-mail address: rollerXXXX@hotmail.com. (Shaun C.)
My 7 has a OEM T-II scoop custom grafted onto the 1st gen hood. The hood was fabricated using both a OEM T-II hood scoop piece and a OEM 1st gen hood with a OEM style fiberglass inner-frame. The overall process took approximately 20- 25 hours of body work to accomplish. The hood was bonded, molded and riveted and then allowed to cure for a while. The rivets were then removed and final body finish was done. Anyone who has ever seen my hood can tell you that it looks OEM. It take time and effort to get it to look right. Also, if not done with care, the molding and bonding will begin to show through in very short time. The heat that a hood takes makes shoody body work apparent, very quick. Mariah can reproduce this hood, but it would probably cost approx. $800...
Hope this helps.
-Bern
ls1swap
Jun 3, 2024 03:25 PM
