Do big pulleys make lights go dim?
Old Mar 22, 2003 | 02:05 PM
pvc's Avatar
pvc
Not a registered voter
I am planning to get underdrive pulleys sometime, mostly because I do high RPMs a lot. But I don't want dim headlights for normal driving and whatever else happens when no power goes to the electrical system.
So just wanted to know how well they work with various member's setups. Is it simple and straight forward to replace the main pulley? I don't know how the timing crap works. And do you notice the amount of power they free up?
Yup thats a lot of questions.
Old Mar 22, 2003 | 03:30 PM
rhinor61's Avatar
I never found the Main pulley replacement to make much difference in power. The main reason to change it out is for the timing marks if you disconnect vacuumm advance and need to advance timing marks.
Also there is a huge risk that you can damage you the seal/bearing on the eccentric shaft if you don't follow specific instruction.
You can get more benefits by upgrading a pre'84 Rx-7 to a '84-85 unit, which does not use a exteral cooling fan.
The biggest bang for the buck is of course is installing a electric fan.
Old Mar 23, 2003 | 05:10 AM
PaulFitzwarryne's Avatar
Apprentice Guru
The design of the pulley is to reduce the revs of the alternator so it will not burn out the bearings at the high rpm of race engines.
If you use the car at low revs the charge made by the alternator is smaller. Thus the battery may go flat in typical street use due to the drain being higher than input. Remember the race cars require less electicity.
What will make the lights dim is a battery which is flat, the long term electrical use is not being met by the slow turning alternator.
Old Mar 23, 2003 | 08:09 AM
smile444's Avatar
Hey,
I have done RX7Carl's Rats Nest Removal, and I cannot get the leading and trailing timing marks to appear. I even went so far as to remove and reinstall the pulley 180 degrees, and it still has the same problem.
Does the Rats nest removal change the timing marks?>
HELP
Old Apr 8, 2003 | 02:42 PM
sonic7's Avatar
did you hook up your timing advance vaccum lines
sonic7's Avatar
sonic7's Avatar
sonic7's Avatar
Old Apr 8, 2003 | 03:50 PM
smile444's Avatar
Yes, I believe so.
Those are the ones that are connected to the dizzy, right?
Old Apr 8, 2003 | 03:53 PM
RotorMotorDriver's Avatar
Seven Is Coming
You can say that again .
~T.J.
Queppa
Nov 18, 2024 03:47 AM
sherff
Feb 24, 2019 12:09 PM
LunchboxCritter
15
Jan 3, 2016 04:11 PM
torky007
Aug 17, 2015 05:14 PM
