Power FC does the pfc plug n play ?
Old Mar 20, 2003 | 10:27 PM
Exclamation does the pfc plug n play ?
hey guys just wondering if the pfc is plug n play with standard maps?here is the mods i have so far :apexi intake hard intake pipes ,greddy elbo and piping 4inch downpipe stock mid,and catback ex,msd plug wires and ngk platinum plugs .i have a walbro fuel pump that has yet to be installed .oh and the pfc to be installed .do i need to wait to install or will i be ok ?
Old Mar 20, 2003 | 10:37 PM
Sl0w7's Avatar
you need to have it tuned... and once it is done dont mess with it...
-Keith
cabaynes's Avatar
Old and grumpy
try the ECU forums
Old Mar 21, 2003 | 12:53 AM
skunks's Avatar
I'm a CF and poop smith
It will run but you wont want to pound it untill you get on a wideband
Old Mar 21, 2003 | 02:20 AM
rynberg's Avatar
Settle down guys, he just has an intake and a downpipe.....with just that, the base map should be fine. To be safe, go to a local dyno with a wideband and do a few pulls to verify that you are not running lean.
I certainly agree that you should do fine tuning to get the most out of the PFC but I disagree that it's not safe to run the base maps with just an intake and downpipe. Just keep the boost to 10-11 psi for now.
BTW, there is no need to install the fuel pump until you have upgraded the injectors. You may have to lean out the lower rpms/idle when using a higher flowing fuel pump.
_Tones_
May 25, 2021 05:37 AM
WyomingTII
Rtek Forum
Oct 26, 2015 05:26 PM
ZacMan
Sep 19, 2015 09:20 PM
