Clutch Fluid
Old Mar 20, 2003 | 08:39 PM
Matty's first 1st Gen's Avatar
Boosted 7
Clutch Fluid
Hey Guys,
I was wondering if synthetic clutch fluid is recommended or if conventional is better, I remember a post a while back that i think said that synthetic was worse, but i can't completely recall and the search isn't working.
Thanks for the help.
~Matt
Old Mar 20, 2003 | 10:52 PM
jeremy's Avatar
male stripper
synthetic oil was considered bad due to its inability to burn readily. but most companies claim it does now, whatever. however i don;t see anything wrong with synth clutch fluid.
Old Mar 21, 2003 | 05:55 AM
inittab's Avatar
I read your email
Clutch fluid? Are you talking about the hydraulic fluid?
Old Mar 21, 2003 | 08:32 AM
jeremy's Avatar
male stripper
i'd guess so, thats what my brain registered. which i though most brake fluid was synth. maybe i need to put the joint down for a bit.
Old Mar 21, 2003 | 08:48 AM
Cloud's Avatar
Boing
Yes, step away from the crack rock...slowly....
Just use a good Dot 4 fluid. Synthetics (Dot 5) do NOT mix readily with pre-existing Dot 3 & 4 fluids, and can jizz all over the inside of your lines (yes, that is a technical term, ask you parents). The benefits of Dot 5 are MOSTLY that it doesn't rape your paint. So, use a good Dot 4 and be done with it. My choice: the Castrol LIMA stuff. Other people love the Ford motorcraft fluid (comes in a metal can), Performance Friction's offerings, and the more expensive brands (Motul, etc.). I find the Castrol everywhere, cheaply, and flush it regularly enough so that I'm not worried about it.
Old Mar 21, 2003 | 09:12 AM
Pele's Avatar
Right near Malloy
Just cover your fenders witha trash bag or a $20 fender cover from Sears, and use the DOT-4, High temp stuff...
You need to completely flush the hydraulic system with denatured alcohol to clean out ALL the old fluid if you go to DOT-5... And on old cylinders, I dunno if the seals would take it... Ditto on the hose...
Not worth is for the clutch... Only worth it on the brakes if you're going for an endurance road race... Even then, I'd reccomend a new master cylinder, new calipers all around, new lines, and flush the steel lines several times.
Hipsiguy
Sep 14, 2015 05:25 PM
Evan Kurtz
Sep 13, 2015 08:40 PM
