power windows >>> manual?
Old Mar 20, 2003 | 08:34 PM
specRX7_22's Avatar
is this a hard task to convert to manual windows? ive heard it is, has anyone done this? or is it easier to put a whole new door on (which includes painting and placing numbers). im not sure this will happen, as the car is already below minimum but its a possibility.
and no more rebuilding the damn switches
Old Mar 20, 2003 | 09:10 PM
rhinor61's Avatar
Window conversion
I find it easier to go from power window to manual unit than manual to pw.
The problem with the mazda power window set up is they have the load of the window motor going thru the switches instead of using relays.
Not sure of the year of your car, but you just need 2 good window regulators (rt/lf) and window winders. And 2 additional bolts for each side to hold the manual regulator. If your door panels are good just drill the whole for the and handles.
Its all bolt up installation, I think you take about 30-45 minutes a side tops.
Good luck,
John
Old Mar 20, 2003 | 09:28 PM
gamble302's Avatar
roadkill hats rock
just do the relay mod, make the switches power relays and have the relays take the load of the windows
Old Mar 21, 2003 | 02:34 AM
Gregs's Avatar
my car is all prewired for power windows
all i need is to swap the doors and get switches
i got power windows in my gsl-se parts car
-greg
Old Mar 21, 2003 | 08:41 AM
Cloud's Avatar
Boing
I really, really need to do this on my blue bastard!
And then, when I get it, the relay mod on the black car! Any links to it Gamble? Give me the links or I give you a noogie.
Old Mar 21, 2003 | 11:22 AM
knight1976's Avatar
hey congrats on picking that car up CLoud. It was a great buy. Im hoping to have something that will give you some competition at the autox and at the drag strip (if ya wanna run) But that is going to be after my SE is done. Still trying to put together the pieces to make a stockport gsl run 13s (highly modified of course). Gonna see if i can pull it off. But anyway GOOD SCORE! Let me know when your gonna take that thing out and run id like to get a friendly competition going
Old Mar 21, 2003 | 01:28 PM
81Rex6port13b's Avatar
I Push My Car Real Fast!
is there any thing i can read on this? and would load on the switchs cause a lag? on mine when i press the button its like a 2 sec delay then the window moves.
Old Mar 21, 2003 | 03:25 PM
cveklund's Avatar
If anyone has all the stuff to convert to power windows, how much you want for it and shipping to League City, TX 77573?
Chris
Old Mar 21, 2003 | 05:57 PM
Eville140's Avatar
On the 84-85 cars with the molded in armrest and power windows. To switch to manual windows you will also need to get differenet door panels. I had both sides of my 84 GSL converted to manul windows. I was also planning on just making holes for the hand cranks. Well the hole for the hand crank comes out really close to the front of the molded part of te arm rest. And the handle would be able to go on, but you would not be able to crank it becasue it would hit the armrest . I just put the power stuff back on. The power motors are very tiny and lite, I woud venture a guess the the weight saving would be under a 1/4 pound.
Later
Randy
Old Mar 21, 2003 | 09:15 PM
specRX7_22's Avatar
i know about the relay mod but i would be doing this for weight purposes not because of the shittiness of the power windows. well that too i guess lol
