Vacum
Old Mar 20, 2003 | 11:52 AM
turboIImadman's Avatar
S.S.S.(sexy,silver,seven)
Angry Vacum
I have no idea where this leak is. It sounds like its coming from inside the car on the driver side, but i cant find any vacum lines in the car. This is why im a FC guy not a FD guy. i checked the line to the pressure sensor and it seems ok. The leak happens during peak boost levels only. ive got the vacum diagrams and the only thing i see close to where im hearing it is the pressure sensor.
Old Mar 20, 2003 | 11:58 AM
cewrx7r1's Avatar
Eye In The Sky
Why does it have to be a vacumm line? Can be an IC or connecting hose, or even a gasket .
Have you checked them?
Old Mar 20, 2003 | 12:36 PM
Mahjik's Avatar
Mr. Links
I would suggest taking a look at the following site:
http://www.autosportracetech.com/RX-...leshooting.htm
It will step you through troubleshooting boost related problems.
Old Mar 22, 2003 | 01:53 PM
saiyan's Avatar
dayem, I also have a leak coming from the driver side too, but couldn't find anything that will lead to that hissing noise... Let me know if you found your leak..
Old Mar 22, 2003 | 06:08 PM
well im begining to think that it might be the brake booster. thats the only thing i can come up with. if anyone has anymore sugestions im open to ideas.
Old Mar 23, 2003 | 06:41 PM
saiyan's Avatar
That's what I was thinking too, but could the brake booster cause boost problem?? I know I'm getting boost, but it's so laggy and not as fast I thought... well keep me update, I'm out of ideas
thanks
FbFuninthesun
Oct 6, 2015 08:03 AM
Tem120
Sep 7, 2015 09:53 AM
vroom7
Mar 15, 2002 01:21 PM
vroom7
Mar 15, 2002 01:18 PM
