Cold weather running
Old Mar 19, 2003 | 03:05 AM
alfred.saunders's Avatar
1982 RX-7 102K
In cold weather with the choke pulled out the care will stall at a stop light until warmed up, also I don't get a voltage to the choke coil. If I let the car ilde with the choke out until it's warmed up it runs good. It also bucks when the choke is out. This last for about 2 miles. Then everything is OK.
Thank You.
Old Mar 19, 2003 | 03:08 AM
680RWHP12A's Avatar
your choke is definatly malfunctioning! when you pull out the choke does the rpm's go up?
Old Mar 19, 2003 | 03:12 AM
Yes the RPM's go to 1500-2000
Thank You
Old Mar 19, 2003 | 03:19 AM
680RWHP12A's Avatar
on the choke cable there is a 10mm adjustment nut on the end of the choke cable where it attaches to the carb. try adjusting that to raise the rpm's alittle. its free to try and it might fix your problem!
Jun 26, 2016 10:21 AM
ncds_fc
Aug 15, 2015 10:06 AM
Wolf_
Aug 11, 2015 04:23 PM
