Does anyone still run a stock airbox?
Old Mar 18, 2003 | 02:32 PM
dgeesaman's Avatar
My car is mostly stock, and I want to keep it that way except for a few basic reliability mods (dp, AST, Y-pipe). For you guys doing the same, did you change out your intake too?
I don't want to add power yet. Maybe in the future.
If the stock airbox is ok for now, anyone know of a good how-to on changing the stock air filter?
Thanks.
94 R-2, 53k.
Dave
Old Mar 18, 2003 | 02:48 PM
meddle's Avatar
I run the stock air box, a drop in, and the RB Scoop. It's not I deal I guess, but I like it because it is quiet.
Old Mar 18, 2003 | 03:09 PM
paw140's Avatar
If you don't want to add power, then there is no point to changing your airbox. As far as changing the filter, it is as simple as taking off a few screws and disconnecting a few hoses, although some of the hoses can be a pain to remove. It's the same as changing the air filter on any other modern car.
Old Mar 18, 2003 | 03:32 PM
rotary-tt's Avatar
2 babies - no back seats
The stock box with K&N filter and RB intake duct works fine for me. You can also just put in the K&N but the cross-over duct is very restrictive. Just pull off the cross-over duct, remove the airbox bolts and the hoses on the back. Going to the RB duct gave better turbo spooling response but made the 3k hesistation problem worse. I don't think you'll notice the 5hp or so the K&N will do by itself but it's a cheap $50-60 mod if you want to play with it a little...
Old Mar 18, 2003 | 03:57 PM
paw140's Avatar
I don't see how your 3K hesitation problem could be exacerbated by the RB duct... Are you sure about that?
Old Mar 18, 2003 | 05:20 PM
adam c's Avatar
Cheap Bastard
A K&N drop in filter will give you better air flow, and is a very good change to make. I run a modified stock air box. Check out this thread:
https://www.rx7club.com/forum/showth...hreadid=121491
Old Mar 18, 2003 | 05:43 PM
apneablue's Avatar
I don't anymore...I currently have the Apexi Intakes (Love the) but going to the Greddy Airinix becasue of a FMIC fitment issue. I like the BOV wooshing sounds you get after you upgrade the stock box...
Frisky Arab
13
Aug 18, 2015 05:30 PM
joel(PA)
Rotary Drag Racing
Aug 18, 2015 05:56 AM
RCCAZ 1
Aug 11, 2015 07:05 PM
