where are the tachometer sensors??
Old Mar 17, 2003 | 09:02 PM
overkill's Avatar
Can someone please tell me where I can find the tach sensor(s) ? My tach has been bouncing around lately, and I'm hoping its the sensor,s and not the gauge itself. If anyone has any info they can share , that wouyld be great.
Old Mar 17, 2003 | 09:30 PM
Resource's Avatar
On the top of the tranni.
Old Mar 17, 2003 | 09:53 PM
overkill's Avatar
thanks, but is that not the sensor for the speedometer? if it isn't then thank
Old Mar 17, 2003 | 09:54 PM
Resource's Avatar
There is one for the tach too.
Old Mar 18, 2003 | 08:55 AM
overkill's Avatar
can you tell me where I can find it specifically, so as not to confuse it with the speedo sensor?? thanks.
Old Mar 18, 2003 | 12:57 PM
Resource's Avatar
That I can't help you with. I'm not sure which one is the tach and which one is the speedo unless I look at it. The manual should tell you.
Old Mar 19, 2003 | 08:58 AM
overkill's Avatar
I have the Mazda workshop manual, and could not find anything on the tachometer. I'll look at the tarnny section. Thanks.
Old Mar 19, 2003 | 07:11 PM
duboisr's Avatar
Does the Ecu read the trailing crank angle sensor and puts out a tach signial . the signial out put can be found in the diagnosis connector .
Old Mar 19, 2003 | 07:42 PM
Duboisr is right and it is not responsible for your tach bouncing. It is the fact that the tach itself is bad and need to be replaced. It is a common problem that is cured by replacing the gauge.
Old Mar 19, 2003 | 10:10 PM
overkill's Avatar
Yes it may very well be the gauge itself. But a mechanic at Mostly Mazda ( m2 performance ) did mention it could be the sensor(s).
My own reasoning for it not being the gauge is this. If the guage was in fact bad I would expect the needle to suddenly fall towards zero then jump back up to the previous revolution. But the particular problem I have with mine is that it occasionally zooms up, which varies from 200 k to 4000k. I have not been able to recreate the problem at will and it seems to do this randomly. Does my reasoning seem logical, or am I missing the obvious?
BTW, I read and reread Diboisr's post, and still do not understand his point.
Old Mar 20, 2003 | 05:32 AM
Rated R1's Avatar
Oji San
Duboisr is a "she" dude.
Old Mar 20, 2003 | 07:39 AM
rxrotary2_7's Avatar
there could be a problem with the solder point on the back of the board. check that. and like she said.... it takes the signal from the cas. you can find the signal in the diagnostic box on the driver side. the coresponding pin is IG-
read the wiring diagrams and see where the signal comes from.
Old Mar 20, 2003 | 12:08 PM
cewrx7r1's Avatar
Eye In The Sky
RESOURCE should not be giving out answers for things he does not know.
Another reason to own a manual and read it.
Old Mar 20, 2003 | 12:37 PM
Old Mar 20, 2003 | 08:35 PM
weblair24's Avatar
That's caused from the lfd, lead foot disorder.
Old Mar 21, 2003 | 04:34 PM
dznutzuk's Avatar
Uncontrollable drifter
Very true, it has nothing to do actually with the connections on the tranny-sort of. The tach signal actually comes from the igniton coil. True it could be a malfunctioning tachometer, and you could actually read it off of the diagnostic module I believe it is IG, can't remember off hand
Old Mar 21, 2003 | 05:30 PM
in my first reply i stated it was IG-
Old Mar 21, 2003 | 05:48 PM
Resource's Avatar
Whoops.....
Old Mar 21, 2003 | 08:53 PM
overkill's Avatar
excuse the ignorance, but would I need an sst to read it from the diagnostic module??
Old Mar 21, 2003 | 10:19 PM
cewrx7r1's Avatar
Eye In The Sky
If you can borrow an oscilloscope, connect it to a trailing plug, you can measure rpm with it.
Old Mar 22, 2003 | 11:36 AM
overkill's Avatar
thanks for your info
rotor_veux
Sep 19, 2015 07:13 PM
