launch techniques
Old Mar 17, 2003 | 08:38 PM
93BlackFD's Avatar
built my own engine
launch techniques
post your launch techniques for a FD
I've been trying to get mine down good, and I always smell the clutch afterwards
i'm positive i'm not doing something right, so share yours!
Old Mar 17, 2003 | 09:01 PM
PVerdieck's Avatar
Here are some "theoretical numbers" from a different thread, talking about gear ratios and all sorts of stuff.
The link is:
https://www.rx7club.com/forum/showth...hreadid=107395
Here's an example (simulated using Car Test 2000)...
RX-7 w/~320 RWHP and 4.10 gears, P275/40-17 tires
0-60 mph - 4.17 sec.
0-100 mph - 10.27 sec.
0-60 ft. - 1.91 sec.
0-1/8 mile - 8.17 sec. @ 90.80 mph
0-1/4 mile - 12.59 sec. @ 114.15 mph
0-150 mph - 24.29 sec.
Top speed - 185.06 mph
40-70 mph - 3.29 sec. (3rd gear start)
60-150 mph - 19.65 sec. (3rd gear start)
100-150 mph - 14.02 sec. (4th gear start)
RX-7 w/~320 RWHP and 4.33 gears, P275/40-17 tires
0-60 mph - 4.12 sec.
0-100 mph - 10.24 sec.
0-60 ft. - 1.85 sec.
0-1/8 mile - 8.17 sec. @ 90.94 mph
0-1/4 mile - 12.61 sec. @ 114.91 mph
0-150 mph - 23.90 sec.
Top speed - 181.40 mph
40-70 mph - 3.08 sec. (3rd gear start)
60-150 mph - 19.21 sec. (3rd gear start)
100-150 mph - 13.73 sec. (4th gear start)
Basically, a little lower top speed, a little quicker (0.2-0.3 sec.) on the high end, and very little improvement below 100 mph and in the quarter mile.
If you're drag racing, you'd be better off with 4.50s or 4.77s, probably, but 4.33s aren't worth the performance gain, in my opinion. If you're not a drag racer, stick with the 4.10s. They're "free".
RX-7 w/~320 RWHP and 4.50 gears, P275/40-17 tires
0-60 mph - 4.10 sec.
0-100 mph - 10.18 sec.
0-60 ft. - 1.82 sec.
0-1/8 mile - 8.17 sec. @ 89.05 mph
0-1/4 mile - 12.61 sec. @ 115.35 mph
0-150 mph - 23.59 sec.
Top speed - 178.39 mph
40-70 mph - 2.95 sec. (3rd gear start)
60-150 mph - 18.89 sec. (3rd gear start)
100-150 mph - 13.48 sec. (4th gear start)
RX-7 w/~320 RWHP and 4.77 gears, P275/40-17 tires
0-60 mph - 4.70 sec.
0-100 mph - 10.05 sec.
0-60 ft. - 1.79 sec.
0-1/8 mile - 8.19 sec. @ 86.78 mph
0-1/4 mile - 12.61 sec. @ 115.49 mph
0-150 mph - 23.25 sec.
Top speed - 173.32 mph
40-70 mph - 2.76 sec. (3rd gear start)
60-150 mph - 18.57 sec. (3rd gear start)
100-150 mph - 13.26 sec. (4th gear start)
First thing you'll notice is that the 0-60 mph for the 4.77 gears jumped back up towards 5 seconds... that's because there would then be two shifts before 60 mph, instead of one. Car Test recommended shifting from 2nd to 3rd at 7,450 rpm at 59 mph. Holding 2nd gear a little longer would result in a lower 0-60 mph time, if that were all you were worried about, but note that 0-100 is down to almost 10 seconds flat with the 4.77s.
Second thing you'll notice is that the car gets noticeably quicker without any increase in horsepower in the higher speed range. 4.77 gears would gain you over a second (1.10 sec.) from 60-150 mph over 4.10 gears without any other changes. From 100-150 mph, you'd gain almost 0.8 seconds. Not bad for no increase in horsepower, and on a track with higher speed corners and straights the car would be substantially quicker overall.
And third, you'll notice that quarter mile performance doesn't really change. And won't, on street tires. The advantage of the shorter gears is lost on street tires, and would only increase the chances of tire spin on the launch. The Car Test recommended launch points for each gear set for maximum acceleration and minimal tire spin are:
4.10 - 1,600 rpm
4.33 - 1,300 rpm
4.50 - 1,200 rpm
4.77 - 1,200 rpm
If the car were on slicks, then you could take advantage of the gearing. Simulating 26x10.50" slicks on the same car, you'd get the following...
4.10 - 12.09 sec. @ 115.31 mph, 6,100 rpm launch
4.33 - 12.07 sec. @ 116.15 mph, 6,200 rpm launch
4.50 - 12.04 sec. @ 116.70 mph, 6,100 rpm launch
4.77 - 12.03 sec. @ 116.67 mph, 6,300 rpm launch
The results would be more noticeable with more horsepower, obviously, but you'd probably pick up a tenth or so and about 2 mph in the traps, just from the gearing change, all other things staying the same.
So how does a gearing change affect normal cruising rpm and highway mileage? With P275/40-17 tires...
Cruising - 30 mph, 3rd gear
4.10 - ~2,241 rpm
4.33 - ~2,367 rpm
4.50 - ~2,460 rpm
4.77 - ~2,607 rpm
Cruising - 70 mph, 5th gear
4.10 - ~2,700 rpm
4.33 - ~2,855 rpm
4.50 - ~2,967 rpm
4.77 - ~3,145 rpm
Mileage (estimated)
4.10 - 16.7 city, 26.2 highway, 19.9 combined
4.33 - 15.9 city, 24.9 highway, 19.0 combined
4.50 - 15.3 city, 24.1 highway, 18.3 combined
4.77 - 14.5 city, 22.8 highway, 17.4 combined
Those numbers were lower then I expected...
Old Mar 17, 2003 | 09:27 PM
cavellm's Avatar
I'd like to see some responses to this thread too.
Still waiting on my new clutch, and afterwards wanna start learning how to launch mine with minimal wheel hop.
Have only tried a few times, dropping the clutch at different RPMS, but usually only got a bunch of wheel hop through the top of 2nd.
I've still got stock suspension setup, @ 80k miles. Hopefully that'll change soon.
cavellm's Avatar
Double post - Please delete mods.
Old Mar 17, 2003 | 09:41 PM
NukeGenius's Avatar
Dim Sum owns you!
I've got a Cusco 2 way LSD and M2 rear toe links and control arms in mine and I don't notice much wheel hop unless I drop it from REALLY high up in the RPMs. The suspension mods make a big difference with that. I haven't driven one without all the goodies but since I've never seen real bad wheel hop with mine, I figure what's on there is working.
Old Mar 17, 2003 | 10:29 PM
scratchjunkie's Avatar
sexy no jutsu
4k feather clutch then quickly but gradually floor it.
Old Mar 18, 2003 | 12:22 AM
adam c's Avatar
Cheap Bastard
Hey someone answered the original question. How about that.
I like to launch closer to 3500. At 4k or over, I seem to get too much tire spin. It's a "feel thing" that takes practice. Obviously you want to get the car going without spinning the tires or frying your clutch. Practice letting the clutch out with out letting the rpm drop, or spinning the tires. Gradually do it faster until you have the right launch.
Let your clutch cool after 2 or 3 tries.
Adam
Old Mar 18, 2003 | 07:13 AM
93BlackFD's Avatar
built my own engine
yeah, keep answering the original question!!
Old Apr 6, 2006 | 12:33 PM
LUPE's Avatar
Stage the car, rev to about 7k. 2nd to last yellow burns Floor it, last yellow burns drop the clutch......
This year I'll be running a 2 step so it will be completely different.
alfred1976
RX-7 Audio/Visual Lounge
Dec 3, 2015 03:06 AM
matty
47
Oct 4, 2015 02:45 PM
Heedlessone
Sep 16, 2015 11:31 AM
IB Cristina
West RX-7 Forum
Aug 20, 2015 05:46 PM
