So I did My Vacuum lines.....
Old Mar 17, 2003 | 08:12 PM
ROTORHP's Avatar
i love boost
So I did My Vacuum lines.....Grief!
I just finished changing my vacuum lines to blue silicone lines. I also polished my UIM and TB while they were off. I changed my fuel filter as well. Now I have a problem. When I started my car, I found that the idle hunts from about 1300rpm to 1700 rpm for a bit then jumps up to 2000 even when it is warm. I can calm it down a bit with a tap on the gas pedal but it goes back to it eventually. If I push in the clutch or turn on the lights it will change the idle as well. I didn't tamper with the settings on the TB either when I polished it. Whats my grief!? Help! Thanks guys Oh ya i checked some threads allready.......
Old Mar 17, 2003 | 08:59 PM
BoOsTin FD's Avatar
Powered by** Rotary
I had similar problem. I fount out that the small hose that goes from pcv valve to UIM has split. I also could hear whooshing sound when i was accelarating.
You can give it a shot and check your hoses especially the ones that connect to UIM
Old Mar 17, 2003 | 09:11 PM
ROTORHP's Avatar
i love boost
I'll go check as well as a few others places...
Old Mar 17, 2003 | 09:12 PM
xstacy7's Avatar
I love when things work
or you can eliminate that pcv valve while your in there, just cap off both nipples
Old Mar 18, 2003 | 12:12 AM
ROTORHP's Avatar
i love boost
Fixed the prob.... all I had to do was adjust the throttle linkage. It sure is picky! I was out about 1/2 to 3/4 of a turn and that is all it took to run like crap. Thanks anyway guys
ls1swap
Jun 3, 2024 03:25 PM
