no tach...
Old Mar 17, 2003 | 05:05 PM
no tach...
my tach no longer functions... How do I test my trailing ignition coil? My 87 T2 doesn't suffer from any driving disablilities, if in fact my trailing coil is no longer working. How might I go about looking at this problem? And one last question what's the max speed in first gear?
Any help would be apreciated...
Old Mar 17, 2003 | 06:24 PM
pull of the plugs when teh car is running. they should spark.
I can get to almost about 28mph in 1st in my 87' N/A, which seems a little low to me.
I'm not sure about other cars.
Old Mar 18, 2003 | 02:05 PM
YOu mean...
You mean I should pull off the wires from the trailing coil and the spark should arch?
Old Mar 18, 2003 | 02:53 PM
HAILERS's Avatar
HAILERS
Try this HIGH TECH solution: Rap on the face of the combination meter (gauges). The tach will return. Magic.
Old Mar 18, 2003 | 03:29 PM
attomica's Avatar
I had a non-funtioning tach for quite a while. A local rotary mechanic suggested I run a new ground wire from the coil's mounting bracket. I did that and the tach now works flawlessly.
I'd check your grounds and even add another.
Old Mar 18, 2003 | 03:53 PM
RexRyder's Avatar
this may be kinda obvious, but did u check the fuses? near the clutch pedal? i also drove w/o tach for 2 months, and now i am a better driver
Old Mar 18, 2003 | 06:59 PM
J-Rat's Avatar
Alcohol Fueled!
Great...Anyone order the combo SHOCK meal? With a side of ELECTROCUTION?
Anyone ever heard of using a TIMING LIGHT to test for spark?
jarrett
Old Mar 18, 2003 | 08:11 PM
I'll try those...
I tried the rapping thing... no success. Tomarrow I'll try another ground.
And what exactly is a timing light?
Thanks for your help so far I'll get back to you guys
Old Mar 18, 2003 | 08:52 PM
J-Rat's Avatar
Alcohol Fueled!
Re: I'll try those...
I am at a loss for words....
The timing light is this interesting little device that senses the spark pulse via "induction". It lights a strobe when it senses this pulse (assuming it has 12v and a ground on the other 2 leads).
This device helps you ensure your vehicle is set to the proper timing. Also doubles as a handy spark troubleshooting device. Also fun to point at people.
Jarrett
Old May 28, 2003 | 02:32 AM
SOIA's Avatar
Take A Look Around
dammit why does nobody tell me if these fixes work!
and if they didn't work what did?
zaridar
Mar 11, 2014 10:23 AM
Take-7
Sep 21, 2011 02:30 PM
that one guy300
43
Sep 16, 2009 11:56 AM
12AllWays
May 26, 2009 07:17 PM
rotarybeat1287
15
Jul 1, 2008 06:13 PM
