What BRAND of pre-mix do you use?
Old Mar 17, 2003 | 12:36 PM
bob13bt's Avatar
Fixed the wheelhop
I dont plan on using the cheap *** stuff for weedeaters and chainsaws, what are you guys using?
Was going to make a poll, but Im not familiar with different brands. Besides, too many polls anyways.
Old Mar 17, 2003 | 12:44 PM
Zach McAfee's Avatar
FTD Wanna Be
Racing Beat sells Royal Purple 2 cycle oil.
Old Mar 17, 2003 | 12:49 PM
RXTASY1's Avatar
I use Redline 2 Cycle oil mixed with a little bit of Marvel Mystery Mud
Old Mar 17, 2003 | 12:51 PM
slow87turbo's Avatar
OH,YOU TOUCHED MY TRALALA
i ues valvoline out board 2 cycle oil. it works and its pretty cheap
ej
Old Mar 17, 2003 | 01:04 PM
SaabGuy's Avatar
I scored Penzoil TCW3 premix at KMart for about 99 cents per pint. Since they are going under, the last oils to go are the 2 stroke type. They also had gallons of stuff for around 15 bux.
Old Mar 17, 2003 | 01:53 PM
dr0x's Avatar
pei > caek
castrol grandprix.
Old Mar 17, 2003 | 02:15 PM
RacerXtreme7's Avatar
NASA geek
Klotz full synthetic Racing oil... mostly used in high performance snow mobiles..... appears to be (just through reading and researching) the cleanest burning and best lubricant available.... ITS NOT CHEAP.. BTW,,, I heard this is what Pedit sells as "rotary specific" in there own Brand labeled containers... but this was just a rumor [wink:]
~Mike....
Old Mar 17, 2003 | 03:42 PM
goodspeed's Avatar
valv.
valvoline tcw-3. Works great. 2.5x /quart.
Old Mar 17, 2003 | 03:48 PM
Turblown's Avatar
Turn up the boost
Thats what I've got.
Rotary Performance Parts
Old Mar 17, 2003 | 07:30 PM
RETed's Avatar
Valvoline "Mult-Use" pre-mix in the blue bottle.&nbsp There is an "outboard" version that's slightly different - I believe the "Multi-Use" one burns slightly cleaner, as the other one STINKS in a rotary.&nbsp $2.30/quart or $6.99/gallon in Vegas.
-Ted
Old Mar 17, 2003 | 07:32 PM
Silkworm's Avatar
Has been.. hangin' around
Redline.
Old Mar 17, 2003 | 09:33 PM
jsotelo's Avatar
I use the Penzoil TCW3. I get it for $2.50 a quart at my local grocery store, but Target, Walmart and OSH sell it as well..
Old Mar 17, 2003 | 09:53 PM
osiris7's Avatar
Marvel nystery oil, your exhaust smells a little like cinnamon..LOL!!!
Old Mar 17, 2003 | 10:06 PM
Manolis_D's Avatar
Valvoline "Multi-use" (blue bottle) here as well... 6.99/gallon in Los Angeles, CA... 128:1
-Manolis
Old Mar 17, 2003 | 10:25 PM
silverrotor's Avatar
-Ted
Same here. I have been using this since day 1.
Old Mar 17, 2003 | 10:38 PM
20B-3Rotor's Avatar
Haltech Dealer
amsoil (series2000)
Old Mar 17, 2003 | 10:50 PM
mmo smells like pepermint not cinnamon but it does give it a hint of candy cane...
Old Mar 17, 2003 | 10:57 PM
adamlewis's Avatar
Back from teh deadly!
MMO all the way.
And I always thought the bottle smelled like Pepto Bismol
Old Mar 17, 2003 | 11:19 PM
HIMNI Racing's Avatar
Rick James
Spectro Golden. I use it in all my high power 2 cycle engines. (Quads,dirtbikes, etc.) I have rebuilt motors that ppl. have used other stuff in and the Spectro Golden burns the cleenest w/less ware. You can get it at most motocycle shops.
Mazdadrifter told me about Amsole<----I think) & that stuff has a great rep. But, I have never used it, so I can't tell you 1st hand how good it is. I would have to run a dirtbike to it's end, then rebuild it, using only the Amsole for the motor's life line. Then I could tell you. Without doing that, I can't say hey or ney.
Old Mar 17, 2003 | 11:24 PM
marcus219's Avatar
FC Mobsta
valvoline here as well!
Old Mar 18, 2003 | 03:48 AM
88 SE's Avatar
I've found all of the premixes to stink up the car anyway
Old Mar 18, 2003 | 09:19 AM
jsotelo's Avatar
As long as it's TCW3 it's gotta be better than than motor oil we were burning before.
I didn't think you could use MMO by itself as a premix.. when I run MMO to clean things out every 3K miles or so I still run premix in there.. is that bad?
Old Mar 19, 2003 | 08:04 AM
deadRX7Conv's Avatar
Opinions are like........
It goes in the gas tank and not on the car!
I've used various tcw3 oils, MMO, ATF, motoroil(in a pinch), hobby shop oil(castor/synth/model engine oil), vegetable oil(should help with the stink), and still looking for other alternatives(usually by accident when bottles in trunk are empty).
Old Mar 19, 2003 | 09:05 AM
bob13bt's Avatar
Fixed the wheelhop
Thanks for all the replies. Now I definately have some good options. Valvoline seems pretty popular, and I was planning on mixing w/MMO. Now, if only gas was cheaper...
rotor_veux
Sep 3, 2015 07:10 PM
