Hesitation
Old Aug 21, 2001 | 05:20 PM
bylinepjw's Avatar
Hesitation
Here's the problem: Stock 12A with K&N and Monza exhaust. When I jump on it, at any RPM, there's a brief hesitation before it blasts off. Almost like the float in the carb is stuck or something. Ideas?
Old Aug 21, 2001 | 07:47 PM
REVHED's Avatar
Hunting Skylines
First of all make sure your accelerator pump is working. Look down the top of the carb and work the throttle by hand. You should see a nice strong squirt of fuel down into the primaries. It if works then it might just need adjusting. You could also try richening the idle mixture by about a 1/4 of a turn and see if it makes any difference. Hope this helps.
rgordon1979
40
Mar 15, 2022 12:04 PM
Sethix
Nov 3, 2017 11:48 PM
dona1326cosprings7
Oct 29, 2015 06:47 AM
lnlreaper
Sep 27, 2015 09:59 AM
