How long to install HKS downpipe?
Old Mar 17, 2003 | 02:56 AM
trixman's Avatar
I just purchased an HKS downpipe, and was wondering how long it would take to install. The reason I ask is because it is my daily driver, and I can't be without the car for too long.
A buddy of mine also highly recommended I tap in a ETG before the installation. What's your take on this, and if I should do this, what brands do you recommend?
Old Mar 17, 2003 | 03:22 AM
It took me about between 1 & 2 hours to install. It depends on how hard your bolts will be to take out.
Old Mar 17, 2003 | 05:39 AM
skunks's Avatar
I'm a CF and poop smith
today i installed a Y-pipe in a friends car, adn with out the intake hoses and cross over pipe/ypipe in there, I noticed that it was amazingly easy to get to, I would really suggest going from above to install instead of going from below. (you can get a 3 foot breaker bar in there from the top )
Old Mar 17, 2003 | 08:03 AM
RonKMiller's Avatar
Blow up or win
Figure 4 hours if you've never done it before, and if everything goes smoothly. You really ought to read about this in ALL the archives before you go at it to save yourself alot of grief. EGT probes are a waste of time, they are "after the fact".
Old Mar 17, 2003 | 09:17 AM
Rated R1's Avatar
Oji San
Your *** better invest in some PB blaster too. That stuff is the best for freeing up the exhaust nuts and studs. Soak them real good and let them sit overnight.
rotor_veux
46
Jun 12, 2018 10:39 AM
gabescanlon
Interior / Exterior / Audio
Aug 11, 2015 05:59 PM
