adjustment on apexi bov ???
Old Mar 16, 2003 | 08:01 PM
has any one found the right adjustment on an apexi bov for stock twins @10 psi?i have tried to adjust it my the vacuum and all but i was wondering if anyone has counted the turns ?this is the dual chamber one .thanks
Old Mar 16, 2003 | 08:53 PM
Mahjik's Avatar
Mr. Links
Re: adjustment on apexi bov ???
The adjustment on the Apexi BOV is just for sound, it's not a boost controller (if that's what you are trying to do). In other words, the holes on the ring denote the loudness of the blow off. The larger the ring you are using, the louder the sound.
Old Mar 16, 2003 | 09:04 PM
no i'm talkin about the spring that u adjust for the psi .it can be adjusted for low or high pressure .if its not set right it will leak under boost.
Old Mar 16, 2003 | 09:16 PM
Mahjik's Avatar
Mr. Links
Unless you are running high boost, you don't need to touch it.
Old Mar 17, 2003 | 06:37 AM
well that would be fine but it has got tobe set to low cause i'm loosin boost .but i dont want it to tight cause that has even worse results .!??
Old Mar 17, 2003 | 08:39 AM
Mahjik's Avatar
Mr. Links
Just follow the steps. Tighten it all the way, and then while the car is running, loosen the bolt until it effects your vacuum/idle. When that happens, just tighten it back a little and there you go.
Old Mar 17, 2003 | 09:53 AM
Engberg's Avatar
That is unless you have another vacuum leak. I have one MIA vacuum leak yet to be discovered and with the spring all out it does not effect my idle vac! It won't hurt much to have it a bit too tight. What is your vac. at idle?
Old Mar 17, 2003 | 11:41 AM
looks like about 14-16.i have had problems with a vac leak as well ,i changed the y-pipe coupler and i went back to my stock bov ,i havent had a chance to run it and see if that solved it .
Old Mar 17, 2003 | 01:22 PM
Engberg's Avatar
If you have the same vacuum at idle after the B.O.V install as you did before you are set. If not tighten the spring and bolt a bit until you get to the vac you were at pre-BOV.
