stonger hatch lifts?
Old Mar 16, 2003 | 05:40 PM
2manytickets's Avatar
I have a mazdaspeed wing on my car and the hatch wont stay up without help, does anyone know of any stonger lifts to keep it up?
Old Mar 16, 2003 | 06:36 PM
T88NosRx7's Avatar
Yeah, I've asked around and people say that I just screwed.
Old Mar 16, 2003 | 06:46 PM
RX7FD's Avatar
maybe you can find some lifts off of another car with a hatchback that is heavier?
Old Mar 16, 2003 | 06:48 PM
JhnRx7's Avatar
Golf Cart Hooligan
it might be possible that yours are getting old...mine can barely lift my hatch and i have the R1 wing. So maby if you got new stock ones it might help.
Old Mar 16, 2003 | 07:11 PM
93BlackFD's Avatar
built my own engine
same prob here, R1 wing, i think we just need new shocks
Old Mar 16, 2003 | 07:12 PM
rotary-tt's Avatar
2 babies - no back seats
I believe that there were 3 different sets of stock hatch lifts. One was for the base with no wiper or spoiler. The other is for the R1/touring to hold up the spoiler. Then I think there is one for the touring with add-on spoiler so it can hold up the spoiler and wiper motor...
Old Mar 16, 2003 | 07:13 PM
saxyman990's Avatar
Place your ad here...
I've also heard that the R1 lifts are stronger than the Base ones. I guess because of the addition of the rear wing on the R1 model..... not positive on that, but definately something to check into.
Also very dependant on the weather. On a hot day, my hatch will pop open on its own as soon as I hit the hatch release. On a cold day, it takes much more effort to lift up the hatch.
Rob
Old Mar 16, 2003 | 07:54 PM
Silent_Stryder's Avatar
Looks like there's only two types of lifts
-8BFA-62-620 (R-1 - Touring ? )
-8BF9-62-620 (Base ? )
And I think I've got the wrong ones on mine.......
Old Mar 16, 2003 | 08:05 PM
Zoomspeed's Avatar
Autozone carries them for about $33 each with a lifetime warranty.
Old Mar 16, 2003 | 08:45 PM
eric e's Avatar
i agree with the age thing more than anything else
they are a mini air shock and wear out
my old 1979 porsche turbo back lid would actually suck the hatch down if you opened to quickly as it was so worn at 200,000kms
eric e
Old Mar 16, 2003 | 10:45 PM
Just that if you're as picky as I am, those won't allow the plasic covers to go back on lower attachments.
Old Mar 1, 2004 | 09:07 PM
rousu's Avatar
I looked on mazdasurplus and it was not clear what might be a heavy duty lift, then I looked at the mazda part number list off this CD of the parts manual I got. Looks like there are two models, but it is not clear which is the heavy duty for use with the wing on the hatch. The CD refers to a model for the hard suspension and one for the normal suspension. I am guessing the hard suspension might be the more powerful gas strut, but the parts list is not clear. Can anybody confirm?
CD:
Right side
8BFA-62-620 hard suspension
8BF9-62-620 normal suspension
Left side
8BF6-63-620 hard suspension
8BF5-63-620 normal suspension
that is eight bee 8B at the front.
That would correspond to previous post of "A" being R1 touring, "9" being base model,
but is the assumption right that the lift struts are stiffer for the r1?
Old Mar 1, 2004 | 10:54 PM
dubcaps's Avatar
that's JDM tyte yo!
Maybe you can get the 99 hatch lifts. I know the 99 wing weighs a hell of a lot more than the 93 and should do the job nicely. I guess your best bet would be to talk to one of the guys on the forum in japan.
Old Mar 1, 2004 | 11:04 PM
bond007's Avatar
Post quality not quantity
Bah! You only think you have it bad.
Disconnect them and THEN try lifting the hatch.
See how you like that...
Regards,
--Ashraf (hatch-strut-less for 2+ years, but no more...)
Old Mar 5, 2004 | 11:30 AM
rousu's Avatar
I have a ghetto stick to hold it up, so at least would not have to hold the hatch up.
Old Mar 5, 2004 | 05:34 PM
adam c's Avatar
Cheap Bastard
I think that the Mazda lifts are expensive. The aftermarket ones are crap. If you don't want to buy new lifts, there is a NICE ghetto mod that works well:
Go to your local hardware store and buy a 10" piece of 3 sided channel aluminum. Get the 1/2" wide (outside measurement) size.
Just slide it over the exposed piston when you open the hatch. It will work great. When you want to close the hatch, simply remove it, and slide it under the edge of your carpet.
Adam
Old Mar 5, 2004 | 06:11 PM
rousu's Avatar
Just got dealer quote for new struts
$145 each, but you get a pair for $290.
Old Mar 5, 2004 | 06:34 PM
user 9348703's Avatar
Yeah they have them available here for the 99pec rear spoiler, so no problem I would think to hold up any of the Mazdaspeed spoilers. The ones for the spoiler are actually cheaper then the ones for NO spoiler "werid"
Old Mar 5, 2004 | 06:36 PM
You paid or got a quote quite a bit tooo high... Around $50 too high for the set.
Old Mar 5, 2004 | 09:23 PM
911GT2's Avatar
The Power of 1.3
What a deal!!
I got replacements from AutoZone, the $33 a piece special. Aside from my order being cancelled twice for no apparent reason, and it taking about 4 months to get them, I'm satisfied.
Old Mar 6, 2004 | 07:50 AM
roadsterdoc's Avatar
94 FD, 69 Datsun Roadster
So, L&R are not interchangeable? How does the left differ from the right?
Old Mar 6, 2004 | 03:03 PM
911GT2's Avatar
The Power of 1.3
Yeah, they're the same. At least the replacements were.
Old Mar 6, 2004 | 05:23 PM
adam c's Avatar
Cheap Bastard
If you have a rear wiper, the wiring MAY run thru the passenger side strut, so it could be different.
I don't have a rear wiper, so I can't check.
Old Mar 7, 2004 | 03:33 PM
rousu's Avatar
Still not clear beyond a guess what might be a heavy duty lift for use with the wing on the hatch. The parts
CD:
Right side
Left side
Additional piece of trivia; the Mazda parts man said that the fourth character in the part number refers to a manufacturer, not an application. So part numbers with another character in the forth place could conceivably be for either application.
Any master parts application list for us cheapies looking for parted out parts for less than the cost of a new car?
Old Mar 7, 2004 | 05:13 PM
adam c's Avatar
Cheap Bastard
I suspect that the only difference in the struts is if it has the wiring for the rear wiper. I would bet that there is no difference in strength.
