Cure for LSD noise?
Old Aug 21, 2001 | 11:30 AM
DONNA's Avatar
Cure for LSD noise?
OK, in the new victoria british magazine, on page 46, there are NEW differential parts available, my question is which one will cure or help the whining noise that the lsd are having....and how envolved is it to replace that part.........thanks,,,,,,,
Old Aug 21, 2001 | 11:40 AM
P.O.S. Racing's Avatar
A fluid change may help some, but the LSD are known for being a bit on the noisy side. Never had one apart, but there are some special procedures that must be followed to ensure correct gear mesh.
Did you get the bolt on your brakes loose?
Old Aug 21, 2001 | 12:54 PM
DONNA's Avatar
bolt still on, but im gonna try removing the top one and hold the bottom bolt with a socket on it and work the calipers to and fro while trying to turn the stuck bolt,,,or something like that, u know what im trying to say, right,,,and, thanks for asking,,,
Old Aug 21, 2001 | 06:12 PM
MarkPerez's Avatar
Tennis, anyone
When you change the fluid in the rear,after it's drained look at
the old fluid,on the bottom look for metel fillings.the more fillings,
the more worn it is.also with the rear wheels off,on each side
move axel,back and forth to feel of any play,the less play the
better,I changed out my rear end for a disk brake/LSD rear,and
used valoline LSD 90 wht fluid,It makes noise,more at 65mph.
but it doesn't howl,,,if the rear howl's,,somethings wrong,,
i'd say it's ok,if it changes then you should look into it though..
On that stuborn bolt you might try an impact tool if you have it ??
Josh83rx7
Oct 2, 2015 07:13 AM
