Apex Seal Chatter or is it Clatter ?
Old Mar 15, 2003 | 12:51 AM
von's Avatar
von
Whatever it is All I want to know is what rpm does the S5 stock 13b with a big streetport usually expierience apex chatter ???
For somone who doesent know chatter or clatter involves the apex seal hitting the rotor housing really fast like vabrating against it instead of smoothly gliding across it.
Or Something like that hehe.
Old Mar 15, 2003 | 10:29 AM
Aaron Cake's Avatar
Engine, Not Motor
Chatter can happen at all RPMs. At higher RPM, I would be worried about eccentric flex.
Old Mar 15, 2003 | 10:48 AM
j9fd3s's Avatar
Community Builder
in my 91 na there are huge chatter marks in the housing. 210,000miles and the car wasnt driven hard, so i dunno what the cause is
mike
Old Mar 15, 2003 | 10:51 AM
Aaron Cake's Avatar
Engine, Not Motor
Lack of lubrication, and general wear on the apex seal grooves on the rotors.
Old Mar 15, 2003 | 11:08 AM
von's Avatar
von
oh i see. Hey you have alot of posts.
Old Mar 15, 2003 | 01:11 PM
HAILERS's Avatar
HAILERS
He has a lot of posts, but no life and no girl friend!
Old Mar 15, 2003 | 01:13 PM
von's Avatar
von
Jelious that he has more posts than you ?
Aron Cake ? Let me know if your ever going to sell your N/A turbo conversion stuff.
Old Mar 16, 2003 | 10:45 AM
Aaron Cake's Avatar
Engine, Not Motor
It's doubtfull that I will be selling it anytime soon, but I will be selling eventually. I will be done some....other unspecified...engine work in a few years after I get tired of the bridged turbo-NA engine.
Old Mar 16, 2003 | 11:25 AM
j9fd3s's Avatar
Community Builder
the seal grooves are all in specs though. what about the seal springs?
mike
Old Mar 16, 2003 | 03:00 PM
Aaron Cake's Avatar
Engine, Not Motor
I would imagine that worn springs will cause chatter, but centrifugal force will tend to keep the seals against the rotor housing.
Old Mar 16, 2003 | 04:42 PM
88 SE's Avatar
Maybe it's from not bieng hard enough on it
I beat the **** out of mine daily. Actually, before I rebuilt the engines, I would beat the living snot out of that car, redline everytime i shifted. No chatter on the housings when i took it apart. I dont think thats the problem
But seriously, its probably lack of lubrication ... dead oil metering pump.
Old Mar 16, 2003 | 04:50 PM
Its usaly S**t quality Apex's.
You dont see expencive Ceramics or even Mazda's own 3 pc Tips doing it.
I have been told its due to the weight of the Apex? as the engine spins faster the Apex (being heavy) creates more force and pushes so hard against the Housing the Oil is removed and starts a Snag then not sort of motion.
Chris
Old Mar 16, 2003 | 05:11 PM
HeffBoost's Avatar
Keep Right Except to Pass
Apex seal chatter begins at about 6000-6500, and gets potentially fatal at 8500, with stock iron seals.
- by peejay, from here
I've read several people say that it starts around 6k, one even said "6,200".
Old Mar 16, 2003 | 06:41 PM
von's Avatar
von
So will I be able to spin to 10k safely with a large *** Godzilla port and say a turbo oil pump? Will this be sufficiant for the engine to last 20k
Old Mar 17, 2003 | 02:27 AM
White_FC's Avatar
Please enlighten me as to WTF a Godzilla port is..
10k you would have some problems with the standard excentric shaft i'd imagine, if your serious about spinning it that high, maybe consider getting a 2piece shaft. Get some good carbon(maybe ceramic?) apex seals aswell.
Old Mar 17, 2003 | 02:29 AM
von's Avatar
von
I thought carbon sealz shatterd when exposed to the slightest detonation ?
how much are they?
Old Mar 17, 2003 | 10:54 PM
White_FC's Avatar
So do most apex seals.. a very good reason why your motor shouldn't be detonating in the frist place..
Probably quite expensive from what i've heard, I wouldn't know though, i've never really looked into it.
Old Mar 17, 2003 | 11:13 PM
nonameo's Avatar
**-P I drive a miata.
have you seen my new King Kong port?
Old Mar 18, 2003 | 12:50 AM
Suds7's Avatar
Hmm, aaron, unspecified engine work? and your av says '2-rotor not enough'. Are you planning a 3 rotor swap?
Old Mar 18, 2003 | 02:06 AM
von's Avatar
von
King Kong Lol I will use that on the next rebuild when I go bridge the Godzilla Port
Old Mar 18, 2003 | 08:35 PM
Suds7's Avatar
godzilla is combined 4 and 6 ports isn't it.
Old Mar 18, 2003 | 11:28 PM
von's Avatar
von
yeah
Snook
Oct 8, 2015 10:09 PM
