Weird Shiat!
Old Mar 15, 2003 | 12:44 AM
Weird Shiat!
I just installed a new MBC, and amungst installing it I ripped out the cold start assist, and the charcol canister. Once I had everything back hooked up. I went to start the car and it rev'd up to 1500rpms, and then died. I tried this several times before I finally got it to idle for about 5 min or so, but as soon as I touched the gas pedal the car died. Once again I kept firing it up, but every time I hit the gas pedal it kept dying!
So I decided to put the charcol canister back in, and I got it to idle a bit longer, but still the same thing kept happening. Now it's being a bitch just to keep it idling without it dying. Oh and the stock boost gauge will sit at "0" once the car dies, but it sit at the bottom when idling. This wasn't a problem before I worked on the car today...... So any suggestions on WTF is going on???Cause now I'm tired and frustrated, and want to start with a clear mind tommorow. Any ideas would be awesome, thanks!
Old Mar 15, 2003 | 12:46 AM
Oh I forgot to mention that it smelled like the car was flooding on me, due to the smell of gas. Oh and the A/F gauge reads rich on start-up then slowly runs down to lean, and then dies, if that helps?
Old Mar 15, 2003 | 02:36 AM
Never mind! I'm a ******' idiot, I just forgot to clip in the MAS! I guess that's what happens when you get tired!
Old Mar 15, 2003 | 02:48 AM
**** never mind! I just forgot to clip in the MAS! I gues that's what happens when you get tired.......
Old Mar 15, 2003 | 11:54 AM
Scott 89t2's Avatar
SOLD THE RX-7!
by cold start do you mean the AWS, or the bottle of coolant??
when you remove the bottle. you have to block the lines going to the manifold. you can't just cut them. other wise it's a big vac leak.
Old Mar 15, 2003 | 10:36 PM
NZConvertible's Avatar
I'm a boost creep...
Re: Weird Shiat!
Originally posted by HKSTurboII
I just installed a new MBC...
...I went to start the car and it rev'd up to 1500rpms, and then died.
As soon as I read this I thought "He didn't plug the AFM back in..."
...the stock boost gauge will sit at "0" once the car dies, but it sit at the bottom when idling.
That's exactly what it's supposed to do. The manifold vacuum when idling is actually well below the bottom of the scale (~400mmHg), but when the engine's not running it'll be zero (atmospheric) because there's no vacuum (obviously).
When the ignition's off it sits at the bottom (instead of zero) because there's no power to the gauge.
Old Mar 15, 2003 | 11:08 PM
Old Mar 15, 2003 | 11:13 PM
silverrotor's Avatar
Bro, you really need to get your Manifold/Boost Sensor fixed! (unreleated topic)
Old Mar 15, 2003 | 11:24 PM
I already did. I forgot to tell you.....
Old Mar 15, 2003 | 11:27 PM
Go figure...you have to many things on the go with your TII.
Old Mar 15, 2003 | 11:29 PM
Yeah, you know how it is!
LongDuck
Oct 7, 2015 08:12 PM
JoesFC
Oct 5, 2015 08:10 AM
Devon Murray
Sep 26, 2015 08:15 AM
The1Sun
Sep 18, 2015 07:13 PM
The1Sun
Sep 15, 2015 04:45 PM
