got my car started...
Old Mar 14, 2003 | 07:43 PM
Ryde _Or_Die's Avatar
Well my car sat for a few months and wouldn't start. Today I put some oil in one leading and one trailing plug hole and cranked it up and it started right up. So does this mean I have low compression or that it was flooded really badly or what?
Oh also, I believe my turbo is blown. Here is what make me think that:
1. absolutely no positive boost
2. car smokes constantly, pretty heavily
3. smoke comes from both sides of the turbo(front/back)
Just want to be sure that it is the turbo. I have my hybrid one I am about to put on as soon as I port the wastegate. Thanks.
Old Mar 14, 2003 | 08:12 PM
mazdamanda's Avatar
Moderatorator
Sounds like your turbo is shot. As for the compression, maybe you had sticky seals, but to be safe buy a compression tester, from Sears or somewhere, and check the compression with the car up to normal running temp. The tester will give you an idea of your compression though it's not always exact and there are a few variables.
Old Mar 15, 2003 | 11:41 AM
I might just have my local rotary shop do a compression test so I can get some numbers and go from there.
I figure my turbo is shot, like 99% sure. Just good to hear that it is for sure before I go to the trouble of taking it off and ****. My shop was going to charge me for 5 hours of labor, which is $300. So I'm going at it myself.
Old Mar 15, 2003 | 01:20 PM
xxxbadassfoxxxx's Avatar
if you do a compression test at a shop it will be like $150 just buy one for like 25 and do it yourself
Old Mar 15, 2003 | 01:27 PM
Old Mar 15, 2003 | 04:00 PM
I think the place over here charges like $60 to do a compression test. I just want my damn boost back already
Old Mar 15, 2003 | 06:49 PM
apexhittinbull's Avatar
think bad water seal - ain't an expert but my FD did similar **** with water seal aka silent assasin.
Monsterbox
Jul 29, 2022 10:48 PM
astrum
24
Nov 15, 2017 08:44 AM
fastrx7man
33
Sep 2, 2015 09:42 PM
smikels
Aug 18, 2015 01:26 PM
